1 - 10 of 10 Posts
On my 04 v8 Tourareg we had to remove the driver door to replace a hinge. After replacing door the car will not start. Recognizes key because everything works except the ignition. HELP!!!
You need to try diagnostic,or try again disconnect all cables from door and then try,there is nothing in door that is important for immobilisation
Diagnostics requires a purchase of one correct? If so what would you recommend?
1 - 10 of 10 Posts
