Hi all, the sunroof drains on my 05 finally started acting up. I've searched hi and low and now I'm stuck. Hopefully someone can shed some light!
To start, the cabin filter is dry and the condenser drain going out the firewall is clear. Rear and driver side sunroof drains are clear as well as the plenum drains in the wheel wells. Upon talking things apart a bit, I think I've isolated the problem.
Where does this rubber hose coming off the front passenger sunroof drain pictured below go to? Water does not seem to drain somewhere past this point and gushes out where the rubber meets the plastic from the buildup!
