Another Injector deviation issue
10K views 184 replies 8 participants last post by  SaVAGeSoot
2012 CATA 3.0l tdi 189k miles
History
New intake rockers and timing chain tensioner on bank 1.
Injector quantity deviation before the job
1.-0.31
2. 0.14
3. -0.30
4. 0.30
5. 0.43
6. -0.41
Injector quantity deviation after the job
1.-5.16
2.-5.19
3. -5.19
4. 5.14
5. 5.14
6. 5.14
Contribution faults on all 6 injectors
New #2 pressure sensing glow plug.
#2 cylinder pressure was 40 bar before the job
#2 cylinder pressure was 63 bar after the job.
Could a size variance in the intake rocker arms cause this. The ones I received from fcpeuro look different from the ones that were on the car however they measured the same. I double checked and the website shows exact fit.
After a compression check this afternoon. I'm not sure what else to look at. The fuel system was fine before the tensioner job.
Any help an advice is greatly appreciated.
Now the DPf light just came on. Could the injectors be dumping too much fuel? There is white smoke, starts out light and increases to substantial. Coolant level remains constant, oil level remains constant.
Is there a way to restore the injectors as if installing new ones - re-enter each one in vcds?
#12 · (Edited)
Nevermind. The cam locking pin in the back will only allow me to move the exhaust cam. So you're thinking move the exhaust cam a couple of teeth?
Man I'm panicking. Completely disregard that last statement.
I suppose the best thing to do is to take the rear chain off, remover the girdle and rotate both cams one tooth in the direction of rotation, reassemble everything and see what happens. I will say though that the teeth are marked by paint where the mesh.
They are off on both banks because that's how the ecu tries to balance everything. It measures acceleration of the crank after each cylinder fires, then adds or subtracts fuel to make them all even. So you have one bank that is good, and one that is bad.
Don't just randomly move anything, it needs to be pulled apart and start again.
You have smoke as you have incomplete combustion most likely.
Yes the manual was followed. Everything I did and touched is in the first post.
Bought all of the locking tools and used them. Its a great system really.
At any rate how can timing be off when cams where locked via the pin in back and the crank was locked? The cams also are painted where the teeth should mesh. Its seems impossible for it not to be timed correctly.
Yes thank you. According to my measurements and the manual a three hole gasket was required.
Do you know how the timing could be off with all locking pins in place? Or does that eliminate the possibility of a mechanical timing issue?
The only other change was the intake rockers.
I know the most logical place to look is mechanical timing but I checked that multiple times and if the locking pins are used I don't see how it can't be a top dead center.
Different country of origin most likely
Can I get the pr code for my engine from vcds? I'm not with the car at the moment.
You should have a PR code sticker in the spare wheel well... or your owner's manual... you can also call a dealer and get them to run your VIN to get them.
visual
visual
Man that is awesome information. Thank you.
Well the ones that came out definitely looked different than the new ones. I just couldn't measure any differences using a pair of micrometers in my hands. Maybe a couple of thousandths would make enough of difference.
I will absolutely follow through and post my findings.
Not necessarily... IF you're confident that you've checked everything and nothing was out of spec, I'd still dig.
Your "thicker" HG would compensate for just a "surface skim".... but we don't really know what was taken off.
How about your valve guides? Were they checked for play? Were they ok?
What compression readings did you get? Are they even across all cylinders and banks?
If valves were replaced, I can only assume that they were damaged in some way... what was damaged on them?
I'm not necessarily suggesting that you fubared something, but with something this complex, it's quite feasible... especially when multiple people are involved, etc. I'll give you a first hand ridiculous example from earlier this week when I took a lawnmower carb apart to fix a no start issue.... it's one of the simplest mechanisms you can have on a ICE, and because I didn't even look at what I was doing, I ended up not clocking the carb bowl correctly upon reassembly, only to end up with another no start condition after the fix.... so the second time I ripped it apart, I actually looked at what I was doing instead of just dismissing it as a "simple" thing that I don't need to use my brain on at all....
Clearly things are bad after "reassembly" in your case as well, so something was overlooked or incorrectly re-assembled.
I don't see how "resetting" injectors or anything like that would "fix" this.
#37 ·
Subbed for interest
May be a silly question but did you mess with the hpfp at all?
#38 · (Edited)
So what actually happened for you to do all of this work?
#42 ·
So here are the visual differences in the rocker arms for the 2012 CATA. I'll edit to include the PR code later.
The rockers in the head are what came out of mine. The only noticeable difference in the pictures is the divet in one and not the other.
#46 ·
But one bank is all new and other bank has how many miles (aka wear) on it? I think whatever you do to one bank you need to do the same to the other so it's symmetrical.
But I have zero experience wrenching on this engine (yet). But that's what my logical brain is saying. I think the procedure only works for all new on both banks or same ware on both banks, no new stuff on one bank and old stuff on the other.
#48 ·
Update: Took some time off. I'll be checking compression today.
I now have the correct matching rocker arms installed, the cam is correctly set. Still has rough idle and white smoke.
Fuel pressure actual and high are close to the factory setting.
If compression checks out good then this must be an ecu issue or the injectors are bad?
Maybe I should have the injectors tested next?
I posted this issue on the Ross Tech site as well. I'm looking for advice on makings sure the injectors and ecu are working correctly together.
Either way I'll post the final outcome.
#49 ·
Man I hate such gaps in responding to threads I can't remember the details
New injectors? If so did you code them properly?
Any tune at all or stock tune?
#50 ·
Thanks.
No they are not new which makes me wonder if they simply need to re-learn or re-enter them as if they were new. I took one off, turned it around and put the nozzle in a water bottle, it is firing but who knows if its firing properly.
I'm beginning to lose hope. I don't know how to check timing other than the crank pin and cam pin lining up.
#56 ·
WTF am I looking at? How did you "fire" the injector? There's no return line on it....... If the engine isn't cranking, the HPFP isn't making pressure ...... :unsure:
Also, back to the chain... you used the correct manual procedure, locking pins, and you rotated the cam locking pin 90deg after inserting it into the sprocket?
#59 ·
Yes sir. But the first attempt I did not know to lock the crank. Thats where the real trouble started and its how I bent two valves on number two cylinder. Lesson learned the hard way.
I've taken this thing apart at least 10 times now and used the manual at every step since.
When I rotate the crank so that the pin goes in the camshaft is perfectly aligned - pins drop in, paint marks on teeth, and reliefs in the shaft for head bolts all align.
#61 ·
Yes. That is correct. To include rotating the cam 30° counter clockwise to put the girdle on and then rotating it back so that locking pin goes back in.
Is it possible that the valve contact could have damage the injectors? Shouldn't the injector firing into the plastic bottle at least would have blown it off? It sounded as if it had the pressure of a typical can of wD40
