1 - 2 of 2 Posts
For transmission fluid I'd like to give amsoil a try. Do you guys use the OE (9.85 a qt) or the signature series (13.75 a qt). Thanks!
As you know I have not used the amsoil , but both are spec'd for our transmissions G 055 025. The only difference I could see between the 2 is the OE does not meet the cold temperature requirement of ATF+4R @ -40°.
1 - 2 of 2 Posts
