1 - 7 of 7 Posts
kristoflangbeen
Discussion starter · #1 ·
I think the ECU dont send commando to injector connector .bosch piezo
Car shut off on highway at 100 km/h
Wont start enimore . Hpfp is chanchet cous of littel metal pieces in pump sonoloide .
I have now 320 bar starting pressure
ECU failure is this common on these motorcode CAS b
Hi, can you please write your native language in Google Translate and then copy and paste the English translation here please
Do you have vagcom to run a check for codes?
Discussion starter · #5 ·
I cannot make out what you are trying to say. Are you saying there is, or there is not metal shavings in the fuel system?
Yes there are metal chaveings in the thank and filter .
I clean it all . And replace filter
And replace the high fuel pressure pomp .
I have now 320 bar pressure on the rail . But ,dont wont to inject diesel -> no start
I dont messure elek to the injector conector ?
Is this common on the v6. Tdi.
Engine code CAS . B
Discussion starter · #6 ·
Engine code CAS . B
I have reading out the system whit autel diagnostic tablet . Alarm fuel pressure
P 0087
Reset several times . And id comming back every time a crank
1 - 7 of 7 Posts
