@Golf Wang
Check your alignment specs (even the ones that they are trying to hit) against the service manual.
Don't pay for\accept an alignment as "complete" until all the values are within range.
Also, if your alignment was already bad, you should've been able to tell by uneven or strange tire wear on your last set of tires that you've just replaced.
@volkswagens-for-life
If your alignment is constantly going out, you have excessively worn out suspension components, or whatever shop is checking your alignment is taking you to the cleaners.
.....or it's all a result of your power mods and the mad tq yo..... and all those larger than HD pickup loads you tow around
Re NA alignments and tire rotation requirements vs ROW
I believe that we do have some crappy roads on this side of the pond, but I also believe that dealers\shops just love to charge people for alignments and tire rotations and it's very easy money (especially when you don't actually complete an alignment as per example above)
I typically only get something aligned or checked if I've had the suspension apart, or if it pulls, or if I experience funny tire wear.
