Bit late for a reply, but I discovered this happening.... If I had the ac in auto and adjusted something manually, like the fan speed, it would go back to full auto after a break... But, if I adjusted several things, like fan speed, temp, air direction, recirc... It never goes back to auto unless I press the auto again. I noticed this because two weeks ago I adjust the temp to low, and left the fan speed at two bars. Came back from vacation and it was hot out but the ac stayed on Low and two bars. If it was going back to auto it would have maxed out the fan and set the temp.
So I don't know if it will stay off, but you could leave it in the lowest fan and set the air diverted to floor and set a different temp.... See if your system will not jump back to auto.
