1 - 10 of 10 Posts
I'll be brief. I had rebuilt and replaced all 4 bags. Used VCDS to calibrate the heights (497 front 502 rear). Drove the car, worked great. Friend jacked the car up to do some work on it, didn't use jack mode. Running gear fault on the dash, try to recalibrate, half the values are invalid, channel 05 not available. I've searched all over for an answer and every thread about this has been inconclusive. Either the thread dies or someone says "just do it till it accepts it".
I spent about 3 hours now trying all kinds of combinations of auto modes, doors closed, this that the other.
the difference i noticed now is when i start the first calibration, the front lowers, and it wont go back up or do anything, and each calibration sits at "wait" indefinitely. I even let it sit on wait for about 30 min.
The only way i can get the front to go back up is to use basic functions and fill front manually. Pump works, i can hear it, i can fill/drain both front/rear bags and tank. but as soon as i try to calibrate, it just drains the front, and nothing happens after, if i attempt to test all the base values i had before, some say valid, others say invalid, and channel 5 is always unavailable and unable to save.
Has anyone ever found an answer to this yet?
2004 Touareg 5L V10
Just did a calibration and had the same problem, it would say value invalid and kept failing, took me a couple if hours of trying all kinds of things, tried disconnecting the battery under the seat clearing codes and manually lowering and raising both front and back a few times, putting it into Jack mode and trying that way then back, and eventually it suddenly accepted my values.. do you have the car in jack mode when trying (did not work for me)? do you do it with the engine running? And you are obviously entering the correct access code
Yeah the access codes are being accepted, and i can't get the car into jack mode after it was lifted without it. I'll press and hold the jack mode for over 20 seconds with no change, where as before id hold for 5 and it'd engage, im going to fiddle with it some more this evening. I've also be disconnecting and connecting the battery aswell, and yes ive had the engine running while doing the calibration.
2004 Touareg 5L V10
Try putting it in jack mode from your diag software, did that too... by the way do you have any stored codes? Might interfere with the calibration, I know it did whe I had a steering wheel angle code
2004 Touareg 5L V10
I do have a steering angle code, and the other one was 01400 (not calibrated) or something like that i think. But they come right back as soon as i clear them
To get rid of the steering angle I had to calibrate it:
Sensor for Steering Angle (G85)
Prerequisites:
  • Start the vehicle.
  • Turn the steering wheel one turn to the right and one turn to the left.
  • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
  • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
  • Ensure that the steering wheel is not moved again.
  • Keep the engine running and do not switch off the ignition.
  • System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Coding-II - 11]
OR
(if Coding-II is not available)
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was succesful, check the sensor again.
[Measuring Blocks - 08]
Group 004
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Discussion Starter · #7 ·
got the steering code to go, but im pretty sure im having a different issue with the suspension now, which obviuosly i'll have to sort out before i calibrate. for one, the whole car is leaning to one side. The rear driver wheel wont lower at all, it seems to be stuck in the max offroad. even when i used the drain front and rear, the car leans to one side, and the rear driver doesnt drain at all. not sure if its the solenoid valve or a sensor. after draining the system (rear) it will show 0 bar (empty) and the rear driver is still max offroad.
If the solenoid valve sends or releases pressure to each bag, then what does the brass fitting on each bag do? is it just a fitting and nothing more?
2004 4.2L Touareg AXQ air suspension
The danger of jacking the car up without selecting the jack mode is you run a risk of 'messing' up the ride height sensors. If the height sensor is stuck then you wont be able to calibrate the ride height. IMHO check the rear driver height sensor on VCDS and manually. On the VCDS- measuring blocks see if you have any variance in the measurement at that corner if you 'bounce' or 'lift' that corner of the car. Also visually inspect the height sensor- see if it's angulated correctly- you could also spray WD40 over the hinge mechanism- unplug and cycle it through up and down motions then plug it back in and see if you can calibrate the system.
Steering angle code wont go away until you succeed in calibrating the suspension. Pay no attention to it, resolve the calibration issue and it will go away.
1 - 10 of 10 Posts
