1 - 2 of 2 Posts
Hello wondering if i could possibly get a bit of help
Have a '16 3.0L air suspension Touareg, and today had it right down on loading level to load some stuff into the back. Then drove off without putting it back up (assuming that it would do it itself), and it didnt go back up, except there was an arrow by where the suspension level shows on the MID between the tacho and the speedo, with a small down arrow by the lowest car icon, indicating it is right down.
When we stopped to put it back up, it wouldnt go back up, whether we tried to do it from the back or the dial in the front.
It doesnt say that there is any faults, and even after stopping it and leaving it for a few hours it still stayed down.
Is there any way that we can get it back up?
Its a british import in NZ, and we've had it for about 3 months, have put the suspension down in a similar way before, and has gone back up no troubles.
Discussion Starter #2
update-
battery went flat while we were trying to fix it- it wouldnt let the key fob go and went completely flat
Battery looked like it had a problem, checked the voltage and it read around 4-5 volts. Charged it slightly to 11 volts or thereabouts the suspension at least leveled off, and we are yet to find out whether it will work.. looking hopeful.. leaving it overnight on charge and will find out tomorrow whether it is fixed completely
1 - 2 of 2 Posts
