1 - 9 of 9 Posts
I don't take delivery of mine for a week still, but was wondering:
Does anyone who has the adjustable air suspension notice the difference between Sport and Comfort?
Same here.
Comfort is noticeably squishy when going through curves, but not scary.
"Auto" really is a mix of both modes. I feel a little more of the small bumps, but rebound is damped more than in Comfort mode.
In comparison to Comfort, I feel every bump in Sport mode. But Sport mode seems slightly softer than my Eos (which has regular "steel" suspension).
There is a noticeable difference for sure.
There is a difference but it also depends highly on the tires and wheel size. On my 20" with 40 profile tires between the three settings is not as much difference as on 17" with 65 profile tires.
Yes definitely - although I'd prefer more difference - Normal is about right, Comfort could do with being softer and Sport could do with being firmer.
I normally just use Comfort but on my first towing trip I discovered that Sport gives a more even ride at cruising speed.
If you drive spiritedly the dampers will still revert to sport even though the dial is on comfort.
Read the SSP's and read the owner's manual.
Reactions: Nightdrv
1 - 9 of 9 Posts
