Good afternoon everyone.
I am writing to you from Spain, to see if you can lend me a hand.
I have changed the front sensor, and I have managed to get rid of the error 01769 that vagcom gave me.
But I still have problems, once I changed the sensor, now it gives me the following error:
Control Module Part Number: 7L0 907 553 G
Component and/or Version: LUFTFDR.-CDC- 3C3P1 3112
Software Coding: 0015521
Work Shop Code: WSC 31414 790 00001
VCID: 377B5D8742CF56A6659-8062
1 Fault Found:
01780 - Sensor for Vehicle Leveling
003 - Mechanical Failure - Intermittent
From what I have read, it may be one of the spring valves, but I think it will be because I have not been able to calibrate the suspension after changing the sensor, let me explain, it lets me enter all the values of each one of the wheels, but when it's time to record those values, on channel 05, it gives me an error and doesn't let me, specifically it says,
ERROR CHANNEL 5 NOT AVAILABLE.
Any ideas???
1 Fault Found:
Any ideas???
