1 - 9 of 9 Posts
2005 v8 165k miles.
Front end not raising. Replaced the pump with a used one thinking maybe mine was bad and seems to work fine.
Just replaced the solenoid valve block. Same problem.
If i swap the front and back lines the front will raise. So if i swap them back to normal, what could be telling the front not to raise?
Any help appreciated.
check that level sensors are properly attached to the upper control arms. Also check the electrical connectors going to the level sensors are properly connected and not full of moisture/dirt.
Left front level sensor is broke. Got one on order. Hopefully that will fix it. Will update when i install. Thanks
Discussion Starter #8
Sensor installed and all is good. Wish i would have checked this first but now i have a 5 year newer compressor and a new solenoid block and learned about the air suspension system. Hopefully no more issues for a while.
Always, always, always diagnose an issue before throwing money/parts at it. Be a mechanic, not a parts changer.
Glad you got it sorted out. :)
1 - 9 of 9 Posts
