1 - 16 of 16 Posts
I have replaced my compressor once after a discomforting constant running gear messages. Replaced the two front suspensions completely when their balloons failed to retain air, still the running gear stuff didn't stop. Though the balloons do inflate to capacity, and raises the car higher when the option is activated.
Now the two front suspensions have completely failed again in less than a year of above replacements. My mechanic checked and fingered the compressor as the culprit. It's not producing good enough pressure while still making the humming noise to indicate it's working. I'm not buying that compressor again I want to convert to spring suspensions (all 4 sides) and do away with the troublesome balloons and compressor, I need to rest from their issues.
But my fear is, will this cause any problem of any kind on the T-reg funky sensors, or with the stability of the car at cruise speed? has any one tried this? my mechanic says there won't be any issues, but I need urgent advise based on experience pls, before I get things completely messed up.
It is possible, but you have to use OEM parts to have stability and reliability of the suspension
But, You gonna Need to remove all the electrical parts as well and do some programming as you will have error message all the time if you will not remove enough parts. But hav you tried to recalibrate the suspension and try to have different approach to a problem? Sometimes the problem is much more simple as it appears :) kind regards, Nikoloz
Thanks for your input Nikoloz, I actually went ahead to change the air suspensions with genuine spring type shocks and so far stability is ok, the car is balanced, now I drive the T-reg like it's a tank, unlike before when I approach a small bump with extreme caution. but I have not done any electrical repairs and some programming on the T-reg ever since so the error messages (running gear, etc) has intensified. Recalibrate the suspensions? well I didn't know about that, my mechanic didn't mention it either. I'll get the electricals sorted and do some programming asap. I'll be on the watch out, but I think I'm cool with the spring shocks for now.
glad you have done successfully what you was planning to do :) please report what electrical mods you will perform and solutions for other in the future :) thank you, kind regards, Nikoloz
Hi Linder, thanks I've seen the kits you're talking about, I purchased complete coil spring shocks for the replacement. My issue is with the WABCO compressor not the balloons. I've replaced this compressor once at quite a cost and didn't get the desired result. I'm pretty scared of another purchase now. If I can fix this WABCO pump with genuine OEM kits and it's fine for use again then it's ok. At least I have two bad sets.
One thing I equally observed with my T-reg now is that without the compressor humming and trying to iinflate the balloons, the car now accelerates faster unlike before when I have to give the damn compressor some time to finish its job before I can move otherwise the car will be sluggish. Now I start the engine and take off smartly, I'm enjoying it.
Hi, I just got myself a fairly used 2006 V10 Touareg with 110250km, my problem is anytime I ran into little pothole, I hear a loud noise on the suspension as if the arm and the tie rods are worn, I have changed my shock settings from sport to comfort and the third one but still the same.Your advise pls
Time to replace some swing arm bushes.
This is a pretty typical maintenance item. When it's needed depends a lot on the type of terrain the vehicle has been driven over. I would take a close look at upper and lower control arms.
Do a search for "control arm bushes", and you will find plenty on the subject. Just maintenance, nothing to be concerned with.
Stuart...
Dears,
Can I use CAT Diesel Engine Oil 15w-40 to service my VW Touareg V10 TDI 2006 model ? See technical sheet below
Performance Requirements
Cat 3406E Endurance Test
Cat C13 ACERT Endurance Test
Cat 3500 Series Test
Cat C13 ACERT Wheel Loader Test Improved Soot-Viscosity & Shear Control High Temperature Shear
Elastomer Compatibility
Piston ring & Cylinder liner wear
Valve train wear, sludge, oil filter plugging Aeration Control
Bearing Corrosion
Cam roller follower pin wear
Copper, lead and tin erosion
Foaming Control
Viscosity Shear loss
Viscosity Increase from soot
Oxidation
Piston deposits and oil control
Test Commercial
Cat DEO
ECF-1
Cat Proprietary Cat Proprietary Cat Proprietary Cat Proprietary
Typical Characteristics*
SAE Viscosity Grade
API Service Classification
Diesel
Gasoline
OEM Performance Level:
Caterpillar Volvo DDC Cummins Mack
Flash Point, °C (ASTM D92) Pour Point, °C (ASTM D97) Viscosity
cSt @ 40°C (ASTM D445)
cSt @ 100°C (ASTM D445) Viscosity Index (ASTM D2270) Sulfated Ash, % wt. (ASTM D874) TBN (ASTM D2896)
Zinc, % wt. (ASTM D4951) Gravity @ 16°C
API (ASTM D287) Specific
10W-30
CI-4, CH-4, CG-4, CF-4/CF SL
ECF-1 VDS-2
CES 20071/76 EO-M Plus 227
-33
76 11.5 145 1.3 11.3 0.146
31.8 0.867
15W-40
CI-4 PLUS, CI-4, CH-4, CG-4,CF-4/CF SL
ECF-1
VDS-3
93K214
CES 20071/76/78 EO-NPP ’03, EO-M Plus
224
-30
120.5 15.5
135
1.3
11.3
0.146
29.3 0.880
*The values shown are typical values and should not be used as quality control parameters to either accept or reject product. Specifications are subject to change without notice.
Hi Chid,
I'm thinking of doing the same thing, can you please (or anyone else) tell if you managed to fix the error message issue? any other issues?
Thanks!
Thanks for your input Nikoloz, I actually went ahead to change the air suspensions with genuine spring type shocks and so far stability is ok, the car is balanced, now I drive the T-reg like it's a tank, unlike before when I approach a small bump with extreme caution. but I have not done any electrical repairs and some programming on the T-reg ever since so the error messages (running gear, etc) has intensified. Recalibrate the suspensions? well, I didn't know about that, my mechanic didn't mention it either. I'll get the electricals sorted and do some programming asap. I'll be on the watch out, but I think I'm cool with the spring shocks for now.
Hi,
How's the ride and what did you use for the conversion? A conversion kit of springs and shock absorbers for an original Touareg? Are you happy with the conversion so far? I am thinking about doing the same thing for my 2006 V8 Touareg.
Dears,
Bearing Corrosion
Foaming Control
Oxidation
Test Commercial
Cat DEO
ECF-1
SAE Viscosity Grade
Diesel
Gasoline
10W-30
ECF-1 VDS-2
-33
31.8 0.867
15W-40
ECF-1
VDS-3
93K214
224
-30
120.5 15.5
135
1.3
11.3
0.146
29.3 0.880
No. You need 505.01 or 506.01 approved oil. See my signature.
Only use the oil recommended by 4ePikanini - that is VW505.01 or VW506.00 - and nothing else under any circumstances.
1 - 16 of 16 Posts
