1 - 20 of 51 Posts
Please help, my Porsche Cayenne Turbo S 2006.
I went for a short drive today approx 10 miles. During the drive I could here the air suspension compressor running all the time. So I stopped and it was running, turned off the engine and still running, I turned around and headed home and got back to my house approx 10miles around trip.
I could here the compressor running, turned off the engine and it was still running (ignition key was in), I could here the compressor running but slowing down (like it had loads of pressure in the line), I frantically looked for the fuse - couldn't find it.
The compressor really slowed down, so i pulled out the ignition key, then 'POP' like a line blew off and the compressor was still running but hissing. The POP came from the compressor area. I still couldn't find the fuse and shortly after the compressor STOPPED.
I eventually found the relay it was buried in the dash, i pulled it out and tested the coil for the relay and it was good and clicking on off on off when i applied 12v.
I hooked the main relay switch contact to 100w12v bulb and repeated the test, the bulb didn't light. I pulled the cover off the relay and the contacts were really really pitted / melted if I pushed the contact down the bulb would light up - I'm pretty sure the relay is knackered and I need a new one.
It sounds like the relay got jammed on some how and wouldn't release, hence it was running with the key out of the ignition.
What about the compressor ? any ideas / comments
thanks in advance
Andy
UK
It sounds like you are going to need a new relay, just for starters. That relay is a very common failure point.
The air lines are easy to fix. It sounds like a repair will be needed. I would start this process by trying to find where the pop and hiss happened. If you are really lucky, you might be able to just put a line back into a connector where it popped out.
If you are not lucky, it is a standard type of air line. Not the easiest stuff to find, but you can buy new replacement line and repair connectors for the line in the aftermarket.
Be glad you caught it early. Most leave the compressor running. Sometime around 25 to 30 minutes of straight running, the compressor will freeze up. At that point you would be buying everything above plus a replacement compressor.
No guarantee, but I give you a 80% chance of reusing the compressor as it is, for what that is worth. Since you caught the compressor before it died and seized, I will break the remaining 20% down to 90% chance a rebuild kit would fix it (under $50) and a small 10% chance that it will need a replacement compressor.
Odds are pretty good for you though. If you had stopped it before the line blew, then a relay would have fixed it. Now you need to fix the line (which might be really easy if you are lucky) and get a relay.
After the above is done, we will be able to watch the compressor and determine if any compressor work is needed.
OK mate thanks for the detailed response.
Just to be clear.....i did not stop the compressor, it stopped itself, maybe there is an over temp sensor on it or something which stopped it or it just gave up or the fuse blew - i don't know at this moment. I was running with the pipe blown off because it was running and hissing.
I couldn't find the fuse or relay in time, it stopped itself. I'm not going to be able to inspect / remove it until next weekend now so I will look into buying a rebuild kit for it, may as well if I am going to take it off the car.
There is a temp sensor on the compressor. The system does have a over heat safety. What I am not sure if a redundant safety is built onto the pump, or if the only safety is if the air suspension controller in the touareg seeing a high reading from the temp sensor and then telling the relay to cut power to the compressor.
In you situation, the above will make a difference.
Nothing has changed in the above post except the odds of you needing to purchase a compressor has went up. Otherwise, continue with the plan. Purchase the relay and find that air leak.
Compressors can be purchased from many places. VW will have the highest priced units. Places like Arnott will have mid priced options with a warranty. Ebay will have some units really cheap. Ebay might be worth taking a chance on, but they will have short if any warranty and many users have reported they are the loudest of the options.
Anyway, we are getting ahead of ourselves. We don't yet know if we fried the compressor. Best luck and keep posting on your progress.
You can get a new compressor for ~$200 USD in north america. I suspect they're also available in your country for a similar price.
X2 on repairing the lines. Shouldn't be too hard to find the break.
VW recommends replacing the relay any time the compressor is replaced.
I don't know if it's necessary to bleed the pressure from the air struts, but I always do before messing around with the compressor. You will have to bleed the air from the reservoir in the future if you ever remove the compressor. Obviously this time, that is not necessary.
BTW, you can bleed the reservoir via VCDS.
I bought a new Relay from Audi £20 !
I looked at the old one and although it appeared to work but it wouldn't flow any current through the main contacts even though you could here them clicking. Wiring up a 100w bulb showed it didn't light up and the contacts were really really pitted and it looked like it could get stuck as it did.
I have removed the compressor and i have found the brown 6mm pipe has blown off the compressor output taking the inside of the fitting with it, my question is :-
Does anyone know what this fitting is and where to buy (UK ) from, what are the dimensions of the threads ? I might be able to get one locally. I phoned Audi and they recognise it but there are not any in the UK and it will have to come from Germany.
Oh - when you remove the compressor the suspension collapses ! be aware !
You can start by looking at some of the parts available on-line. Locally, you would look for a commercial supplier for pneumatic and air hoses.
Touareg 2004-2010 (7L) Air Suspension Parts & Conversion Kits
I added a few pics from RMT. The first is a coupler to fix a broke line. The second is a repair kit to fix a line that broke near a screw in connection. They also sell the line and the connectors separately.
https://www.carid.com/volkswagen-touareg-air-suspension/
Air Supply - Spare parts around the air suspension
For future reference. Move the front left seat all the way up and forward. Then go in from the back - there is a big orange blade fuse. That's the compressor fuse. 40 amps.
Carry a spare!
Discussion Starter #10
All fixed and back on the road. I could not get hold of the M7 fitting in the UK, even Audi couldn't get hold of it.
The new fitting (readily available) was drilled and tapped 1/8 BSP to 6mm push in (good for 20bar) and pressure and leak tested. A long way round to fix but cost only £3 from a local hydraulics company. I fitted a new piston ring kit as well whilst I was in there.
Some photos
Good post with the pictures - they always help. Glad you are sorted.
Yeah! Glad you are back on the road.
_______________________________
But the correct way to fix this would have been to let the dealer install a new relay and a new compressor. Since the system lost air, they are worried that the shocks might be compromised, so you should get four new air shocks also.
Parts are back-ordered, but we should be able to get you back on the road in about six weeks. We will park it out back and give you a call when ready.
Would it be a problem for you to go ahead and pre-pay us for the repair work today?
LOL!
That bill at a Porker dealer would be more than the car is worth too!!
Discussion Starter #17
This is why the Relay was stuck on and giving the compressor 12v all the time and I couldn't turn it off , I bent up the contact to have a look and this is what i found.
My car has done 99,000 miles just to give you an idea.
Discussion Starter #19
melted contact ?
Yes, definitely which caused it to stick, you can see that the contacts did not perfectly align and caused a ridge. Well if draws close to 40A then I'm not too surprised.
Like I said - this is a 100,000 mile example ! I guess off and on 10,000 times caused this so no surprises.
I was lucky - my compressor didn't burn out otherwise it could have been expensive.
My current spend was £20 relay + £20 for a compressor ring and seal kit and the fitting for the compressor outlet was £3.
1 - 20 of 51 Posts
