V10 tdi 2003
Sent from my SM-N910C using Tapatalk
Can you give us some more detail on your solution/fix for this?Fixed without vcds put some lubricant in to compressor air tube.
The front sensors and sensor balljoints is good? Show problem on video.......When I'm in off-road or X the back end of my truck will raise. The front end raises and then lowers. The fault will appair on the dash "stop fault running gear" I can hear a hissing noise out of the front right shock (no leak). Today, I replaced the suspension air strut pressure valve and no luck...and help or ideas?
