221 - 240 of 267 Posts
Banned
Discussion Starter #222
Coated them in Loctite Marine Grade
Anti-Seize. Awesome product. Protects from salt.
Loctite Marine Grade Anti-Seize - Product Search - Henkel
To any other Canadians, report your failures here https://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/PCDB-BDPP/fc-cp.aspx?lang=eng
The case is still open, to allow more data to be collected. This means that there simply weren't and still aren't enough cases with failures to warrant recall. This is why it is important for people to not remain secretive about this. I think the worst thing one can do is to fix this on his own dime in a private shop, and never have it documented by a VW dealership and anyone else with some power.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
I noticed that my 07 has what looks like white spray paint around where the fittings screw into the shocks... must be some sort of anti-corrosion paint... I wonder if the previous owner had that done, or they did it on all 07's?
Banned
Discussion Starter #224
Banned
Discussion Starter #225
The "white spray paint" sounds more like a spray on grease to keep road crud at bay.
As suggested, stick your finger on it and if it is grease, keep it topped up.
As for anyone else, clean the area up, let it dry, and then protect it, topping up the protection before the winter.
Hi All,
Is it fair enough to say that the potential corrosion is due to salt on the road. I read with interest that most people with this issue are from locations where snow falls.
Regards
Gerald
Yes.
But unless you are in a desert, I'd carefully clean them and put a dollop of grease on them.
very sad to hear of a failure of this type
while in the hunt for my V10 I was aware of this issue and careful to examine the fittings during inspection
on one such occasion I viewed a vehicle with a previous fitting repair and was informed that the repair was no wheres near the ripoff at the dealer
the dealer may take a by the book approach, but a repair is a repair and a guarantee is a guarantee
the dealer really took advantage of the situation
I'd like to stay away from this dealer and if you could please warn us of this dealers name , greatly appreciated
My egg has fittings that appear to be in very clean and un corroded state, regardless I sprayed the fitting well with a rust protector "rust check" and then a higher tacky agent with a lithium base to it.
the repair should't be more than 2 hours labour plus the cost of a new fittings
now all you air suspension owners, set on high level, get your head inside the wheel well with a can of rust protector and spray!
a squirt today will keep the pos dealer away!
Clean them carefully first BEFORE you spray! Don't go sealing the salt in!!
chip, chisel , sand, polish, buff, acid bath, soda wash, then spray the F'n **** in there and rest assured that you'll be ok
oh, and I forgot to mention in my first response to this issue,
the dealer must have physically, not accidentally by not using the suspension locking feature put force upon the fitting.
the top of the strutt and air line/ coupling are quite stationary in position unless acted upon by direct force,
the guy in the shop just couldn't leave well enough alone or needed to make a good day's pay
just a theory
now let it snow so I can check out my new Hakkapelittas!
Another leaking UK early touareg...
Dealer over the road after a bit of a fight ordered the bits as per the TSB but is now insisting that due to the fitting being "tight" and "heavily corroded" that the whole strut is replaced @ £1600+labour+tax. The opposite side isn't far behind in terms of visible corrosion.
I'm going to get a second opinion as the dealer near my work haven't exactly been spectacular.
EKTA seems to suggest the very early cars the struts are only available as a complete unit... Mines an early 2003...
Try asking on the UK Touareg site if you haven't already.
myTreg forums
One of the members there did a repair job as he wasn't about to cough up that kind of money on an ageing car and there are some pix too.
Someone else had the union drilled out and the hole re-tapped. I think that may have been someone on here whose dealer was a bit more savvy. Go back through this thread.
Banned
Discussion Starter #236
drill
tap
insert
go on vacation with the money yu just saved!
+1!!!!!
Best advice, and basically how they repaired mine if one goes back 20 pages or so.
The only dilemma that really remains on the repair procedure, is if the mechanic is comfortable enough to drill, tap, insert with the housing still on the vehicle, or would rather take it off the vehicle(more labour time charged of course), and work on it on a bench. From what I understood, although I could be wrong, so someone with some knowledge please do chime in, is that it would be highly undesirable while tapping, to allow debris to fall inside the hole into the housing. The dealer told me if this were to happen, a new air suspension housing would have to be ordered. Now I find that slightly far fetched, but I'm no expert on this either.
any seasoned tech knows how to tap a hole without contaminating with debris
for those who don't, grease the tap, secret revealed
drills by nature remove debris from inside outside , the grease helps to maintain this debris on the tap once the tap has penetrated and then been removed
"air shocking" isn't this
Lol
This proves again that today's mechanics cannot repair anything.
They are very skilled at replacing components though!
I don't think the warranties on today's vehicles actually make provision for the above type of repairs.
The result is that the franchise workshops don't train their 'mechanics' to do repairs, even on out-of warranty vehicles.
I suspect (and would not be surprised if it is so) that most franchise workshops don't even have a set of taps and dies!
the most valuable tool is our brain
if the franchise shop is unwilling to "repair" then "remove" the vehicle form the shop
franchise shops these days for the most part robots sent here from the mother ship
Dark Lord of the Sith
Just cleaned mine up and winterized them. They were clean and corrosion free, but I took some good warm soapy water and used a 2 inch paint brush (worked great for getting all around the fitting) to clean it good. Then clean water to rinse all soap and gunk off. Then used the wifes hairdryer (shhhh) to dry it good. Sprayed white lithium grease all over it to get in the nooks and crannys, then smeared a good amount of some amsoil lithium grease on the fittings.
15 minutes of preventive maintenance for some good piece of mind.
