1 - 12 of 12 Posts
I finally charged my A/C for the first time on the Touareg only to discover an audible leak near the driver front wheel. Put her in Xtra high jack mode and took off the wheel well cover to see where the refrigerant was leaking from. Found the part on jim ellis vw parts schematic and ordered it from vwparts2go for just under two hundred clams. Looks easy enough to do (2 torx bolts?) once the plastic is removed since the system is already evacuated (vag com reads 0.0 bar refrigerant pressure and no more hissing) thanks to corrosion and/or rubbing on the refrigerant line. Hope it is as easy as it looks!
Part number:
7L0820722F
Anyone perform this already and have any wisdom or know what size torx bolts are used for the A/C system components?
Discussion Starter · #2 ·
Just got this message from vwparts2go:
Justin, I put in the order to Germany to get your part and I got a report back
and it looks like there are none left in the German warehouses. So
unfortunately, I will not be able to get it for you. I will go ahead and cancel
and refund your order. Thanks!
We appreciate your business!
Have you tried going to an aircon specialist and getting them to make up a pipe for you?
Discussion Starter · #4 ·
Anyone know of a competent A/C specialist in upstate NY?
DIY Refrigerant Line Fix
My DIY for fixing the AC leak:
Cut out the damaged portion
Build the replacement line using:
Dorman 800-632 3/8" X 12" Straight Rigid Aluminum Tubing
JEGS Performance Products 100392 -6AN Tube Sleeves
JEGS Performance Products 100382 -6AN Tube Nuts
JEGS Performance Products 100202 Flare Union
Tubing bender
37degree flaring tool
File and sand down the Touareg aluminum tubing because it is too large for the AN6 fittings (OOOOPS!)
Fit it together and tighten the fittings
Replace the drier using Spectra Premium 0210098 A/C Accumulator. Oil those O-rings!!!
Vacuum the system
Fill her up and tighten the fittings until leaking stops but don't over torque.
Enjoy cool air from the vents =).
Reactions: petzku
Tretx - Nice DYI! do you have some specs on the filling tool?
Discussion Starter · #8 ·
I used an Interdynamics filling hose with the attached gauge and trigger from my local advance auto store.
I purged the line by pulling the trigger while attaching it to the low pressure fill port to avoid introducing air into the system. I added three 12 oz. canisters of refrigerant which is close to the 39 oz. specification for rear A/C. I didn't have a scale to weigh it on so I just stopped after the third can. I added one 8 oz. can of the PAG oil which I hope results in close to the 10 oz. specification. I do not know how much oil was left in the system before adding, but I do know the area around the leak was pretty oily so I think it had lost a bit.
Pretty rudimentary setup, but the A/C is blowing nice and cold... I even had to turn my wipers on in full sun to clear the condensation from the outside of the windshield.
I like doing that bit!
Discussion Starter · #10 ·
Still blowing nice and cold.
I've replied to your other post on the same subject.
1 - 12 of 12 Posts
