581 - 590 of 590 Posts
Learner
ok, I thought I’d done research on this for Q7… found it!. So, a 375mm front, 350mm rear?… the front is the issue, but I did just find one source for a High Carbon disc, so there’s hope… but at much higher unit costs than previous gen discs. This rotor is designed with a different type of hub than past generations… at this moment that front brake kit is double past models! Ouch 🤕! Still want those RPO codes, though … to be certain.
Geoff
Brakes (This is for Australia)
Front
V6 210kw 6 Piston with 350 mm Rotors
V8 310kw 6 Piston with 400 mm Rotors
Rear
V6 210kw Single piston with 330mm Rotors
V8 310kw Single piston with 350mm Rotors
will get to the PR codes soon.
Reactions: QPower1
MY21 V8 R-Line Grey
Front
Rear
V8 310kw 6 Piston with 400 mm Rotors - 1LV (...same as Q7 OE code 4M0 615 301 AE I believe. 400mm, 38mm thick, 57.4mm offset, 68mm bore, 5x112mm PCD)
V8 310kw Single piston with 350mm Rotors - 1KQ (...350mm, 28mm thick, 36.4mm offset, 68mm bore, 5x112mm PCD)
Touareg Brake Specialist
2004 V6 w/package 1 and HID, bought 10/03
Discussion Starter · #584 ·
Just a brief reminder that we are very much still offering brake kits for all MY Touareg, and all Porsche/Audi marquee equivalents… holding parts pricing while prices are beginning to rise from inflation… remember inflation?? Been awhile…
contact us directly at our number to inquire.. all business is done by phone call for surety!
Geoff
Discussion Starter · #585 ·
Just a reminder that I’m very much in business and supplying kits worldwide for all Touareg models plus all stable mates.
To whom this will concern, please leave this thread undisturbed as ATP is active!!
regards,
Discussion Starter · #588 ·
Just a reminder that I’ve been subsuming added increases while only passing along the augmentary costs, diluting margin, but keeping price increases minimal.. I’m not adding margin to my added increases. A thought to consider.. Ready and willing to ship brake kits for all models plus Phillips D1-S HID lamps at new lower prices for OE grade … now $100/pair when purchased with a brake package.
Geoff
Discussion Starter · #590 ·
In need of complete brake overhaul. Pads, rotors, hardware, front and rear. ‘09 vr6. What’s the best way to contact you?
Truly… by phone when I can answer any questions, and we can discuss the minutia of your vehicles buildout, as there are two rear brake options to confirm; there’s a small 6x4 label printed with three digit alphanumeric codes in your tire area under the hatch. Let’s get a look at it and send me back a picture to my number below?
Call me anytime business hours…
Geoff
