1 - 8 of 8 Posts
I am selling my BC Coilovers with Air bag spring kit. All hoses and push to connect fittings will come with it and I have approx 5mtrs of extra hose as well. All the fittings are brass and high quality, they were purchased through a truck air bag trade supplier. Cost was just under $200.
The coilovers have only done approx 7k. all working perfectly. Fully serviceable and parts are through just jap.
I bought it and installed to try and do a setup that allowed stock or lower height for street and a lifted height for off road.
It wasn't able to get the height with it lifted that I wanted so I have returned it to the off road setup with lifted springs.
This kit will work really well to lower your Touareg or Cayenne. As you can see from the pictures of my car it looks awesome. Ride is excellent and fully adjustable damper setting.
I set it up with a tyre valve for the front pair and 1 for the rear pair that I could just hook up to an air compressor at home.
I would suggest going with an on board compressor for best results. I was only testing so I never got to this stage.
Looking for $1800 and can arrange freight at buyers cost. Located in Brisbane Australia.
Sent from my SM-G930F using Tapatalk
The beauty of the adjustable coilover is you get the full travel of the shock as the thread of the strut is shortened not just shortening your springs.
you could go stock height to as low as you want really. that pic is about 2.5 inches below stock height.
2006 V8 Touareg AIR, nav, hid
Cayenne should also be a direct fit. If you don't move it here, a Cayenne user might be interested.
Q7 could also run the shocks, but I don't see the typical Q7 owner as having any interest.
1 - 8 of 8 Posts
