Just picked up a 2013 Touareg TDI with 200K miles for cheapish.
As I am about to start the intake cleaning and oil cooler reseal job, I wanted to get onto a tune before long.
Looking for:
I'm considering Malone Stage-2 with just the DEF delete, although can any of the deletes be added later with flashzilla?
Thanks!
Looking for:
- More on the side of fuel efficiency over total power
- Keep EGR since I am based in Maine, unless warm-up times are not that bad on these?
- Keep DPF and tune it out later when it does fail, unless I can run it with a hallowed-out DPF? Since the delete kit is about the same cost as a replacement DPF.
- Delete DEF system since I cant see a negative to this delete.
Thanks!
