1 - 4 of 4 Posts
Hello All,
I have a 2014 T3 with the RCD 550 fitted to it and I now need to add a reverse camera to it.
I've searched the forum and could not find a solution. Did also an online search and found a number of generic solution such as fitting it to the rear-view mirror, not sure if that's the best option but I would be open to it.
I did not consider upgrading the head unit to the RNS model as it would be very costly.
Would love to hear more from anyone with experience/knowledge of the matter, any advice is helpful.
Many thanks!
you have several options:
1. If you want to stay OEM using RCD550 you will have to install a video interface to your car then connecting a backup camera to the interface, difficulty MEDIUM cost around 500$
Link: https://goo.gl/u8Qv7n
2. Also if want to stay OEM you can replace RCD550 with RNS850 not sure how the procedure is done but I know it's a lot of work, difficulty HARD cost more than 2200$
link: https://goo.gl/ai45LU
3. you can buy an aftermarket screen which looks like OEM then connecting a backup camera to it, this way will you can skip the complication of installing a video interface. difficulty EASY cost around 400$
Example: https://goo.gl/hRdgAf
Many thanks for your great contributions! I'm leaning more towards either replacing the unit with an android one, or adding it through the rear view mirror.
1 - 4 of 4 Posts
