1 - 3 of 3 Posts
Hi, I had a base 2008 V8 and swapped the standard audio system for a Kenwood in-dash Nav unit that also had Bluetooth, Sirius, etc etc. I just traded that Treg for another 2008, this one has Luxury Pkg 2 and Technology Pkg, I like the Nav much better but no Bluetooth. The salesman didn't know if VW parts/service can add Bluetooth, any idea? Or does anyone know of an aftermarket Bluetooth that would work the the Audio/Nav unit that's in the 2008? Thanks in advance.
IF you have the color MFD you should be able to add the VW 9W7 Bluetooth module, which connects under the passenger seat. Might need some Vag-Com to get it to work but it is compatible as long as you have the color MFD. If no color MFD you will need either the 9W2 or 9W3 units. Several 9W7's available on eBay.
1 - 3 of 3 Posts
