Hello guys,
can u help me out please? I would like to know if pump could be dead. My neighbour asked me if I could check lights on dashboard. First issue was NOx sensor which I replaced and nox error (efficiency too low) disappeared, but AdBlue failure message on dashboard stayed (no vcds error). After few test drives, this error came up:
Is pump dead or issue is somewhere else? I want to drop Adblue tank to check wiring and components.
I have checked replacement for pump: #561 198 969. I didnt find any leaks so I suppose that pump is responsible for this.
Thanks in advance
Code:
9645 - Reductant
P20E8 00 [237] - Pressure too Low
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 155656 km
Date: 2021.12.22
Time: 12:27:54
Engine speed: 732.50 /min
Normed load value: 60.0 %
Vehicle speed: 1 km/h
Coolant temperature: 68 °C
Intake air temperature: 4 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.500 V
Unlearning counter according OBD: 40
Outside air temperature: 1.0 °C
Pressure sensor for reducing agent: measured pressure: 821 hPa
Sensor for reducing agent tank temperature: temperature: 11.0 °C
Reducing agent pump: activation: 80.00 %
Thanks in advance
