Went on a 50mile drive @ 50MPH after trying to reset Adblue. Didn't reset. I ran another quick scan immediately after. I also pulled the injector off the line to see if it was wet. It didn't appear to be. By running the
Injector for Reductant (N474) should it kick on the pump and spit out fluid or just activate the injector? It's pulsing and buzzing but dry.
I want to isolate the problem but I'm not sure if it's kicking on the pump which would possibly point to a clogged line or pump. I see a reductant pump and purge valve but would like to test further before purchasing replacement parts.
Code:
Sunday,03,December,2023,12:59:51:40630
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVGFK7A93AD003975 License Plate:
Mileage: 162640km-101059mi Repair Order:
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 46 56 65 68 6D 6E 76
77
VIN: WVGFK7A93AD003975 Mileage: 162640km-101059miles
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 0010
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CAT) Labels:. 059-907-401-CAT1.clb
Part No SW: 7L0 907 401 T HW: 7L0 907 401 K
Component: 3.0TDI FSA G000AG 0140
Revision: 33H02--- Serial number: VWX3Z0J2910804
Coding: 0421002A590F0168
Shop #: WSC 30948 003 1048576
VCID: 3C21257FEA724C8A33B-5184
VINID: 9E65D66C74490D1500003247149C877C2E
3 Faults Found:
008250 - Reductant Level Sensor
P203A - 000 - Electrical Malfunction - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:14:34
Freeze Frame:
RPM: 0 /min
Voltage: 12.39 V
Load: 2.0 %
Temperature: 2.7°C
0.0 bar
Temperature: 15.3°C
008332 - Control Circuit for Reductant Pump 1
P208C - 000 - Short to Ground - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:14:34
Freeze Frame:
RPM: 0 /min
Voltage: 12.54 V
Load: 2.0 %
Temperature: 2.7°C
0.0 bar
Temperature: 15.3°C
008354 - Purge Valve for Reductant
P20A2 - 000 - Short to GND - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:15:20
Freeze Frame:
RPM: 0 /min
Voltage: 11.55 V
Load: 2.0 %
Temperature: 2.7°C
0.0 bar
Temperature: 15.3°C
Readiness: 1 2 0 0 1
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 LD HW: 09D 927 750 LD
Component: AL 750 6A 3405
Revision: 00H89000 Serial number:
Coding: 0004984
VCID: 7BA3E663AFFC8BB27A1-5160
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0004354
Shop #: WSC 31414 790 00001
VCID: 46D54797A4EE065A55F-8012
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 226
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:11:54
Freeze Frame:
Count: 128
Count: 4865
Count: 294
Count: 1
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 135 C HW: 7L0 909 135 C
Component: Kessy 6850
Revision: 00H22072 Serial number: VWX3Z0J2910804
Coding: 0000232
VCID: 313F044B3D60B1E290D-8064
Component: ELV XXXX
Part No: 7L6 907 040 AL
Component: CLIMAtronic R/L 4537
Coding: 0023030
VCID: 7AADE367A096B2BA617-802E
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2004
Revision: -0004--- Serial number: --------------
Coding: 230002002F00BC000000000000000000
VCID: 0059918FC64AE86A2F3-8054
Address 0F: Digital Radio Labels: None
Part No SW: 8E0 035 593 Q HW: 8E0 035 593 Q
Component: SDAR SIRIUS H08 0160
Revision: 00000000 Serial number: AUZ4Z7M0616558
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 372B3A53D3446FD2DE9-8062
2 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 226
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:12:31
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 11
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:14:48
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 A HW: 7L0 959 655 A
Component: J234__0D VW8T 0270
Revision: 92013027 Serial number: 003C6001FBHM
Coding: 0012356
VCID: 3B232663EF2C4BB23A1-806E
Subsystem 1 - Part No: 7L0 959 339 E
Component: BF-Gewichtsens. 007 0009
Subsystem 2 - Serial number: 52670
Subsystem 3 - Serial number: 0001.01.000000700000000000Ăż
Subsystem 4 - Serial number: 000000Ăż
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010011
VCID: 42DD5B8788C63A7A797-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 972 A HW: 7L6 920 972 A
Component: J285 KOMBI-INST. 9833
Revision: KHH05V46
Coding: 0007201
Shop #: WSC 80093 222 71269
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:14:43
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 972 A
Component: J533 GW-K-CAN TP20 9833
Coding: 57E2F799E1066002
VCID: 70B9C14FF6AAF8EADF3-8024
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:14:43
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No SW: 7L6 919 879 B HW: 7L6 919 879 B
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1439802T1F1502
VCID: 46D54797A4AE065A55F-8012
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 015F948BCD10E16220D-5160
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L6 959 933 A
Component: 4M HSG 0601
Coding: 0000085
VCID: 40D9518F869A286A6F3-4B1E
Subsystem 1 - Part No: 7L0 959 701 M
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 M
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L0 959 703 C
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 C
Component: Tuersteuergeraet HR 0201
Address 56: Radio
Cannot be reached
Address 65: Tire Pressure Labels:. 7L6-907-273.lbl
Part No SW: 7L6 907 273 E HW: 7L6 907 273 E
Component: J0502 RDK 0006
Revision: 00004006 Serial number: 00000600013677
Coding: 0040008D8D0000000000000000
VCID: 3A2D2367E01672BA217-806E
1 Fault Found:
02214 - Tire Pressure Warning
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 226
Mileage: 162558 km
Time Indication: 0
Date: 2023.12.01
Time: 23:13:16
Freeze Frame:
(no units): 63.0
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 392F3C6BE55079A228D-806C
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 140210 054 0403
Coding: 00208941
Shop #: WSC 31414
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 B HW: 7L6 959 107 B
Component: J605 HECKKLAPPE 1310
Revision: --H05--- Serial number: --------051887
Coding: 0122110
Address 6E: Ctrl Head Roof Labels: None
Part No SW: 7L6 919 044 AD HW: 7L6 919 044 AD
Component: J702 Dachdisplay 0401
Revision: 1030006S Serial number: 00000000153765
VCID: 79AFFC6BA5D0B9A268D-802C
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 392F3C6BE51079A228D-806C
7 Faults Found:
00434 - Left Front Inner Parking Aid Sensor (G332)
009 - Open or Short to Ground
01548 - Sensor for Parking Aid; Rear Right (G206)
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
00437 - Rear Right Inner Parking Aid Sensor (G335)
00436 - Rear Left Inner Parking Aid Sensor (G334)
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
01545 - Sensor for Parking Aid; Rear Left (G203)
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005196094
Coding: 0002077
VCID: 3A2D2367E05672BA217-806E
End----(Elapsed Time: 02:10, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
