Drove my T-reg yesterday with no problems. Today, right out of the garage felt like I had a bent wheel rim, significantly out of balance wheel, or significant suspension issue. All tire pressures were WNLs. Took vehicle to tire store, they rebalanced all tires, rotated tires, and re-torqued all wheel lugs. No change in symptoms. Could not see any significant issues with brief inspection. The suspension was level all the way around vehicle. Any ideas?
Thanks!
Do you feel vibration/thumping if you place your hand on the top of the cubby box between the two front seats as you drive along?
If so, centre bearing as above.
Agree... More details where noise or feeling is coming from. Is it worse at different speeds? Could be drive shaft.
