Acquired V10 and CEL codes... what a surprise
313 Views 14 Replies 2 Participants Last post by  SaVAGeSoot
Bought an 2006 V10 project car, 185k miles on the clock. Owner had bought it knowing that tandem pumps needed changing (passenger side leaking), never got around to it and needed to get rid of it. I actually was able to drive it the over 500 miles back to my house (over 2 days), only had to put in a little over a quart... well who knows with the stupid dipstick. Anyways, previous owner had told me there was a fuel trim code P0170 - fuel trim. When I finally got there and ran VCDS myself, the P0170 code was gone and I got two new codes:
P0252 - Injection Pump A Cam/Rotor: Range/Performance (Injection timing out of range)
P0257 - SAE - Injection Pump B Cam/Rotor: Range/Performance
Both come on as soon as I start vehicle. I cleared it a few times on my drive back only for it to come back. One time I cleared and went at least 40-50 miles before stopping - neither were pending codes before I shut off engine. It's just when I start it they pop up every time.
Only thing I can find here on this site for P0257 is this thread: P0257 on V10 TDI
Guy claims that a dirty air filter caused the code, and it went away when it was changed. I haven't even looked at the air filter to see if it's dirty, but can that really be it?
The other code is more worrisome, and the reason why I think it's worrisome is because this car has an unknown service history surrounding it. In other words, cams haven't been inspected and they might be starting to go. However, I do not hear the typical banging sound that these vehicles tend to make when the cams start to go bad. The car runs fine; true that I literally just drove this for the first time so I have no frame of reference, but it seems to accelerate fine.
Going back to P0257, the owner changed the fuel filter before selling it to me, so that's clean. I had the idea of maybe running some diesel fuel additive (Amsoil diesel injector cleaner) because it was sitting for 2 years and almost never started before I drove it the 500 miles back to my house. I use Amsoil on my other TDI (03 Golf ALH engine) and the guy who sells me Amsoil gave that to me for free, so that's why I have it.
Anybody have any experience with these codes, or would have an idea why both would show up right on startup like that? Thanks.
See less See more
1 - 15 of 15 Posts
Post full scan, codes and FF data
Scan didn't take as long as I thought it would. Here are the ones of interest:
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGMª8472
Revision: --H01--- Serial number: VWZ3Z0E6407658
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 61D7778BBB89F39BAC-515A
VINID: 9E65E09071DC0C650014608314020F5463
2 Faults Found:
005206 - Exhaust Gas Temp Regulation for Bank 1
P1456 - 000 - Limit Reached
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 298948 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Inj. Quantity: 0.0 mg/str
Temperature: 156.0°C
Duty Cycle: 0.0 %
Temperature: 15.3°C
000368 - Fuel Trim; Bank 1
P0170 - 000 - Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
Temperature: -90.0°C
Temperature: 138.6°C
Readiness: 1 1 0 0 0
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª8472
Coding: 0060575
1 Fault Found:
000371 - Fuel Trim; Bank 2
P0173 - 000 - Malfunction
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
There's plenty of other addresses it scanned and came back with faults (like the lamps... car is yelling at me that bulbs are out every time I turn on the car but they're all working), but I included the ones that are engine relevant.
What I never understood about these scan tools is that how can a code that shows up in an address bank is a different code from what shows up when you use the OBD-II function? Because as you'll see there's the fuel trim codes that pops up in the engine addresses (that's probably what the former owner saw), and yet what pops up when you scan via OBD-II are two completely different codes... I'm confused.
See less See more
I have no idea what you're going on about. Is there something in the partial information that you're asking about?
I'm asking why when I scan via OBD-II I get codes P0252 and P0257. When I do a full address scan via VCDS, those two codes don't even show up, and instead I'm getting codes P0170, P0173, and P1456. At least those are all the relevant engine codes in the address scan.
OBD-II is for certain things
You didn't post the requested information, so I have no idea if your software is anywhere close to updated, and I can already see that you're missing label files for your engine....
See less See more
Apologies, you did ask for FF data and I didn't provide that... that chart was helpful.
Freeze Frame:
Friday,26,May,2023,11:16:02:49241
VCDS Release 23.3.0 (x64): Generic OBD2
Freeze Frame Data for address 10
PID02 DTC that caused freeze frame data storage: P0252
PID04 Calculated load value: 0.0 %
PID05 Engine coolant temperature: -40 °C
PID0B Intake Manifold Absolute Pressure: 0 kPa abs
PID0C Engine RPM: 0 /min
PID0D Vehicle speed: 0 km/h
PID0F Intake air temperature: -40 °C
PID10 Mass Air Flow: 0.00 g/s
PID11 Absolute Throttle Position: 0.0 %
Freeze Frame Data for address 11
PID02 DTC that caused freeze frame data storage: P0257
Codes:
Friday,26,May,2023,11:18:16:49241
Mode 03: Emission related fault codes
Address 10 (Engine): 1 Fault Found:
P0252 - Injection Pump A Rotor/Cam: Range/Performance (Injection timing out of range)
Address 11 (Engine): 1 Fault Found:
P0257 - SAE - Injection Pump B Rotor/Cam: Range/Performance
Address 1A (Auto Trans): No fault code found.
And when you say "full scan", you mean at the top menu in VCDS software you click "auto scan"?
See less See more
Yes, but given your vehicle vintage, it won't work that easy... you'll probably have to select the correct platform from the drop downs.
Stuff like this, can potentially mean that your VCDS is out of date. Have you updated it?
Here's and extract from mine as an example:
VCDS said:
Friday,26,May,2023,06:35:20:38535
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 23.3.0.0
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVGEP9BPXEDxxxxxx License Plate: TOUAREG
Mileage: 179130km-111306mi Repair Order:
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0011
Revision: 56H21--- CVN: E7FCBDE438D3FF82755A21130E1FC39E
Coding: 292A4012233600050000
Shop #: WSC 93288 999 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
ROD: EV_ECM30TDI0117P0907401K.rod
VCID: B777000D0EDB832BB2-80E2
VINID: 9E65D58094A0A1550004320618BB2177C4
Readiness: 0 0 0 0 0
Furthermore, with a V10, especially of that vintage, there's a high probability that your control modules (especially engine ones) are on very outdated firmware.
You'd actually have to pay a dealership to check\update these for you unless you find someone very well versed in V10s with the correct tools\access\software.
Check out some of the dates being reported by your modules!
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Lots going on.
See less See more
I did select the right one from the drop down menu, 7L Touareg from 03-06
Here's mine:
`Friday,26,May,2023,10:27:34:49241
VCDS Version: 23.3.0.0 (x64)
www.Ross-Tech.com
Seems like it's up to date
Oof, that would be unfortunate.
See less See more
I called my local VW to see if there are any updates to ECMs available, and none such exist.
I'd suggest posting on the RT site as those guys will be way more informed than the local dealer who probably didn't even look anything up. I'm not sure if you can see firmware/software updates on erWin but it would be worth looking into it.
Was camping on the weekend, so I never looked at your info too closely.
I once again encourage you to post a full scan.... you have lots of weirdness here.... look at the FF data.....
So your engine isn't running when the injection timing is out of range?
It's also freezing AF outside, and there's no airflow, etc..... how can ANY amount of timing be out of spec based on those parameters?
You said you drove it, so it must run....
Why are all these sensors reading zero?
So have you logged all these sensors? Are they all dead, or do they just read flaky and drop the signal when your DTCs pop or how do you explain this?
Sure thing, here's the full re-scan. I say re-scan because remember that this was sitting for 2 years. And this ECU starts doing weird things when battery discharges. It was throwing a bunch of faults for other small things, but when I cleared all the codes, cycled the engine and did auto-scan again, here's what I got:
Code:
Monday,29,May,2023,12:14:07:49241
www.Ross-Tech.com
VIN: WVGPT77L36D056235   License Plate: NVXXXX
Mileage: 299190km-185908mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L36D056235   Mileage: 299190km-185908miles
   Coding: 0060575
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2063.12.00
                    Time: 00:00:00
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    (no units): 1.0
Readiness: 1 1 0 0 1
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004200
   VCID: 7F13D1F32D3D256BBA-515A
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D6FEBFB67B1F77BE8-515A
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137     HW: 5WK 484 92
   Component: 29 Kessy            6700
   Revision: 67005614    Serial number: VWZ3Z0E6407658
   Coding: 0131304
   VCID: 70F102CF60634A1333-515A
   Component: ELV                 XXXX
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   Shop #: WSC 00000 000 00000
   VCID: 77E339D3050D1D2BF2-51D0
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0020030
   VCID: 459F831B0F61BFBBB0-515A
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
1 Fault Found:
00003 - Control Module
            014 - Defective
             Freeze Frame:
                    (no units): 2.0
                    Temperature: 13.0°C
                    Temperature: 10.0°C
                    RPM: 0 /min
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111838
   VCID: 47838913356DADAB42-515A
   Coding: 0060575
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2063.12.00
                    Time: 00:00:00
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    (no units): 1.0
Address 15: Airbags        Labels: 3D0-909-601.lbl
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0006614>
   Coding: 0012341
   VCID: 28412AAF983342D3AB-515A
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
            001 - Upper Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Component: Lenksäulenmodul     3401
   Coding: 0010032
   VCID: 44999E1F045B86B3A7-515A
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 48818A2F3873A2D34B-515A
Address 19: CAN Gateway        Labels: 6N0-909-901-19.clb
   Part No: 6N0 909 901
   Component: Gateway K<>CAN      0101
   Coding: 0000006
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
            004 - No Signal/Communication
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
Address 22: AWD        Labels: None
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D0F7B3B179107FBB8-51D0
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 66DD649752A794A359-515A
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 367DF4D74287242329-515A
Address 36: Seat Mem. Drvr        Labels: None
   VCID: 77E339D3050D1D2BF2-515A
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50B1A24FC0236A1313-515A
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000003
   Shop #: WSC 26027 444 57540
   VCID: 67C3699355AD8DAB62-515A
1 Fault Found:
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 439B9D030155818B9E-4B00
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
1 Fault Found:
00987 - Lamp for Brake Light; Left (M9)
            009 - Open or Short to Ground
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 7L6 035 456
   Component: 08K Audioverst.     0105
   Subsystem 1 - Part No: 7L6 035 456
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014062
   VCID: 357FF3DB5F812F3B20-515A
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C69E6FF7CABFE73DF-515A
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 3861FAEF4893D2533B-515A
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J5X0299
   Coding: 0000101
   VCID: 72F508C76E6F7803C5-515A
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 3967FFEB7399CB5BC4-515A
End-------------------------(Elapsed Time: 08:24)--------------------------
Note that the Fuel Trim codes never went away after cycle. Neither did the Airbag on the passenger side, annoyingly. Have no clue about oxygen sensors and their status on this car, maybe I can change them out when I do tandem pumps? I know there's one for each bank of cylinders, where exactly are they located?
See less See more
What's the -90 reading from? Might wanna sort that out unless you believe that temp is possible.
Should be after the turbos, before the cat..... engine drop will be required for removing\replacing them.
1 - 15 of 15 Posts
