1 - 3 of 3 Posts
Hello Fellow Members,
I believe that my ABS Pump has failed. I am getting ABS Light Indicator as well as ESP Light on. Below is the relevant VCDS scan readout. I also checked fuses to confirm the issue was not a fuse issue.
Took the car into my local dealer as well, and they also indicated that they believe the ABS Pump has failed. Now I will purchase a new ABS Pump - I believe the part No. is: 7L0 614 517 CBEF.
My question is what is the coding process using VCDS that has to be done when you replace the ABS Pump ? Is there a link/source to a clear process for ABS Pump coding for the Touareg?
I have searched online/googled and most of what I can find is coding process for 1 - Audi.....
Any help would be appreciated.
VCDS
Self-Diagnosis Log
Monday,27,January,2020,17:39:00:20387
Page 3
VIN: WVGZZZ7LZ7D068231 License Plate:
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 K HW: 7L0 907 379 K
Component: ESP ALLRAD MK25E1 0302
Revision: 00H53001
Coding: 0008578
Shop #: WSC 31414 790 00001
VCID: 418920F81CC66947E8-8014
1 Fault Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 8
Reset counter: 148
Mileage: 102982 km
Time Indication: 0
Date: 2020.01.27
Time: 06:03:48
Freeze Frame:
Count: 64
Count: 12289
Count: 107
Count: 1
Coding a module in VCDS is a basic process. You go into the module, enter a security code (if required), enter the new code, and hit the 'Do it' button. The coding for your existing module is listed in your auto-scan, and that is what you would enter.
If you have a legitimate Ross-Tech interface, you are guaranteed support from Ross-Tech. Contact them for additional information if you need help.
Thanks for the response. Ok, I will proceed to order the new module, and as I do have a legit Ross Tech interface, I will also contact them for support/instructions prior to attempting the procedure.
1 - 3 of 3 Posts
