1 - 3 of 3 Posts
Installed a new ABS pump / module on my 04 Touareg V10 and VAG-COM has no communication with Abs. I was told that either the vehicle or module had to be programmed or coded? Is this possible with no communication?
Administrator
Try recoding the CAN Gateway, don't actually change the code, just select DO IT. This will force learning of new CAN devices.
Aircooled,
I have a thread on TDIClub.com (I am sure your login still works).... involving this very same problem (99.5 VW Jetta TDI w/ 5-spd manual):
ABS Module not responding in VAG-COM - TDIClub Forums
No VAGCOM communication with ABS Module!
I have replaced the ABS module several times. All wiring and power is good. I don't think I have a CAN Gateway, but I have heard that the Instrument module acts as a CAN Gateway. Can I try this possible fix? Have you seen this work before? And are there any risks, or is it "couldn't hurt to try"?
Thanks.
1 - 3 of 3 Posts
