I have a 2005 V6 with 169k miles. Had a whirring sound from front drivers side wheel.
Mechanic replaced the wheel bearing but then got an ABS fault. Replaced the speed sensor on the same wheel still ABS fault.
I have read where you may need to clean or replace speed sensor on the other side due to air gapping causing a difference in signal strength.
Anyone have this same experience and what worked to fix. BTW the whirring went away but the ABS fault is causing shifting issues unless shift in manual.
Appreciate any thoughts.
