1 - 15 of 15 Posts
Hi All - Hoping for some help tracking down a ghost in my 2007 V10 TDI
I have a few symptoms, all intermittent and all persistent. Vehicle has 162K miles on it. I was going through a series of Check engine light and intermittent white smoke coming out the back. Took it to a local german vehicle specialist, and to the dealer, along the way replaced both batteries, the fuel filter, EGR system, both turbos, combo pump (coolant and fuel?? under the hood), both MAF sensors, and a thermostat. Meanwhile I still have an intermittent (but now more regular than ever) check engine light. I get a frequent smell of diesel fumes in the passenger compartment, and the tail pipes do have a black soot on them. Smoking seems reduced, but is not absent, and perhaps is the regen mode for the particulate filter? Kessy stopped working a few months ago, and in getting the part number to figure out where to find a replacement (still need one) I noticed some bare wires on the module immediately next to the Kessy (not sure what this box is or where to find out). I'm also getting an intermittent ESP light on the dash, followed by rougher shifting. This happens even when either on the highway, or even stopped, it used to come with a lit up "tree" but hasn't done that in a while. The mechanic indicates my errors are all intermittent and that the sensors all appear to be operating within normal range most of the time.
I bought the Vag.com scanner and have posted the faults below. I note the repeated appearance of intermittent. Not sure what would cause this. Any help is greatly appreciated. Note - aside from all these issues the T-REX drives like an absolute beast, and does not appear to suffer from any power loss etc. Occasional light shudder when smoking, but barely noticeable.
------- VAG Scan -------
Sunday,09,February,2020,11:20:57:13256
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WVGPT77L07D005583 License Plate: DT13
Mileage: 261810km-162681mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L07D005583 Mileage: 261810km-162681miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 070 906 016 CQ HW: 028 101 196 2
Component: V10 5,0L EDCG000AGM™8472
Revision: --H02--- Serial number: VWZ3Z0F6488104
Coding: 0060575
Shop #: WSC 31414 000 00000
VCID: 619FA4EE0D5A968FA69-5184
1 Fault Found:
005379 - Load Signal from Alternator Term. DF
P1503 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 9
Reset counter: 255
Mileage: 260807 km
Time Indication: 0
Freeze Frame:
RPM: 714 /min
Speed: 13.1 km/h
Load: 0.0 %
Voltage: 13.00 V
Bin. Bits: 00101000
Load: 0.0 %
Bin. Bits: 00100001
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
Component: AL 750 6A 0856
Revision: 00H51000 Serial number:
Coding: 0004216
VCID: 7F5B02969BEE407FB0D-5160
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D27389ED162926FE21-5184
No fault code found.
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 A HW: 5WK 485 02
Component: 29 Kessy 6700
Revision: 67006015 Serial number: VWZ3Z0F6488104
Coding: 0147688
VCID: 313F14AE1D3A660F769-5184
Component: ELV XXXX
1 Fault Found:
00003 - Control Module
012 - Electrical Fault in Circuit
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: 77ABEAB6B3DE783FF8D-5184
Address 08: Auto HVAC Labels: None
Part No: 7L6 907 044 T
Component: CLIMAtronic 2+2 4222
Coding: 0020030
VCID: 45D7507EB9B2DAAFBA1-5184
Subsystem 1 - Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 0400
2 Faults Found:
00709 - Sunlight Photosensor 2 (G134)
009 - Open or Short to Ground - Intermittent
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3002
Coding: 0110815
VCID: 47CB5A7683BEC8BF48D-5184
3 Faults Found:
01117 - Generator Terminal DF Load Signal
008 - Implausible Signal
00907 - Intervention load Management
000 - -
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGS™8472
Coding: 0060575
1 Fault Found:
000371 - Fuel Trim; Bank 2
P0173 - 000 - Malfunction
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
Temperature: -90.0∞C
Temperature: 138.6∞C
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0008268;
Coding: 0012341
VCID: 2809F9CA2EE027C7A17-5184
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 D
Component: Standheizung E1MAC
Coding: 0000100
VCID: 33331EA6E726541F045-5184
1 Fault Found:
01126 - Engine Speed Signal
008 - Implausible Signal - Intermittent
Part No: 7L0 959 933 H
Component: YM HSG 0400
Coding: 0000085
VCID: 41DF446EAD9AF68F869-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Discussion Starter #2
Got all the lights to come on driving into work ESP and Tree lit up on a smooth dry highway.
235412
Had hoped for some input, did I list too many things at once for someone to make suggestions? Of note. The entire ABS issue goes away immediately when I restart the car. Then comes back again after a few dozen miles or so. Any thoughts?
All I can say from the picture is "That don't look good!"
Look up the threads about a bad canbus wire near the drivers door. That is my first guess and it is not that hard to confirm. The dropout of the network means a lot of different random errors get set.
So, clear codes, drive the vehicle a while and pull codes again. If it is the canbus wire spice going bad, you will get a new bunch of different random errors set.
PS: The canbus splice will always fail. It is not a question of if, just a question of when. It will pretty much go after it gets wet, so it varies. But sooner or later, it will happen.
OK Thanks very much. I'll start there and see where this leads.
I finally got a free weekend to get into the wiring harness. I checked all the splices, and all looked good to me. I added solder to them and re-sealed, but my problems still remain. If anyone has any tips about what to chase next I'm all ears!
Do the same codes keep popping up when you clear them, drive the vehicle and re-scan? Or do they change depending on the day?
Discussion Starter #8
Yes they are mostly the same. Occasionally they come in as "intermittent", and typically include alternator, fuel trim, and exhaust gas temperatures. This rig is exhausting me. Feel like its time to push it off a cliff.
Here is from today.
Coding: 0060575
VCID: 619FA4EE0D5A96833C5-5185
5 Faults Found:
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 19
Reset counter: 255
Mileage: 261812 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.15 V
Bin. Bits: 00001000
Load: 0.0 %
Bin. Bits: 00100001
005206 - Exhaust Gas Temp Regulation for Bank 1
P1456 - 000 - Limit Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264138 km
Time Indication: 0
Freeze Frame:
RPM: 1323 /min
Speed: 63.1 km/h
Inj. Quantity: 15.2 mg/str
Temperature: 510.0∞C
Duty Cycle: 0.0 %
Temperature: 12.6∞C
000368 - Fuel Trim; Bank 1
P0170 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 265064 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001011
Bin. Bits: 00000000
(no units): 0.0
005782 - Powertrain Data Bus
P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 265064 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001011
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 1 0 0 0
I have some nice new ones as well.....
Coding: 0004216
VCID: 7F5B02969BEE40732A1-5161
1 Fault Found:
Coding: 0022786
VCID: 3D27389ED162926378D-5185
1 Fault Found:
Coding: 0147688
VCID: 313F14AE1D3A6603EC5-5185
Component: ELV XXXX
3 Faults Found:
00087 - Terminal 30 for Starting Relevant Consumers
00668 - Supply Voltage Terminal 30
VCID: 77ABEAB6B3DE7833621-5185
1 Fault Found:
002 - Lower Limit Exceeded - Intermittent
Coding: 0020030
VCID: 45D7507EB9B2DAA320D-5185
2 Faults Found:
Component: 3002
Coding: 0110815
VCID: 47CB5A7683BEC8B3D21-5185
3 Faults Found:
000 - -
Coding: 0060575
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
005216 - Exhaust Gas Temp Regulation for Bank 2
P1460 - 000 - Limit Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 264138 km
Time Indication: 0
Freeze Frame:
RPM: 1323 /min
Speed: 63.1 km/h
Temperature: 504.0∞C
Duty Cycle: 0.0 %
Temperature: 12.6∞C
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 265064 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001011
Bin. Bits: 00000000
(no units): 0.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 265064 km
Time Indication: 0
Freeze Frame:
RPM: 588 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.92 V
Bin. Bits: 11001011
Bin. Bits: 00000000
(no units): 0.0
Coding: 0012341
VCID: 2809F9CA2EE027CB3BB-5185
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 23
Reset counter: 255
Time Indication: 0
Part No: 7L6 953 549 H
Component: Lenks‰ulenmodul 3401
Coding: 0010032
VCID: 44D14D7AB288E3AB373-5185
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 R
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
VCID: 48C9594A8EA0C7CBDBB-5185
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Coding: 0000100
VCID: 33331EA6E72654139E9-5185
2 Faults Found:
01444 - Under-Voltage Shut-Off (Automatic)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9D1AAD6B02F0BA3B-5185
3 Faults Found:
00908 - Control Module for Wiper Motor
00484 - Vehicle Position Recognition Control Module (J603)
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
1 Fault Found:
00926 - Terminal 30
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D47A85EA14262E328D-5161
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
VCID: 3829298AFE40B74BABB-5185
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
3 Faults Found:
01898 - Steering Column Axial Adjustment Sensor (G358)
006 - Short to Plus - Intermittent
02332 - Position Sensor for Backrest Adjustment (G440)
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 M
Component: Navigation 0047
Coding: 0000101
VCID: 50F9712A76F00F0B83B-5185
Coding: 0000085
VCID: 41DF446EAD9AF6831C5-4B1F
5 Faults Found:
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 47: Sound System Labels:
VCID: 55F7803E4C026A2350D-5185
Note: Excessive Comm Errors
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000009
VCID: 78A9E98ABEC0774B6BB-5185
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X018
Coding: 00000034
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000034
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 E
Component: Radio 0047
Coding: 0014062
VCID: 353720BEE9524A23B0D-5185
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C21359ACA789B6B4F3-5185
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 180506 014 1201
Coding: 00208933
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
Coding: 0000002
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J630347
Coding: 0000101
VCID: 72BDDBA2D8BC1D1B55F-5185
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: 7L6-959-107.clb
Part No SW: 7L6 959 107 HW: 7L6 959 107
Component: J605 HECKKLAPPE 1110
Revision: --H05--- Serial number: --------002778
Coding: 0022110
1 Fault Found:
03234 - Functionality Limited due to Critical Electrical Condition
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 91
Time Indication: 0
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F2C8EC54AAE43545-5185
Definitely a lot of weird things going on. The Air Quality Sensor, open or short to + is an easy one. Someone most likely forgot to hook the sensor back up when the wiper cowl was re-installed.
Is your alternator original to the car? I'm only asking because there are a lot of low voltage codes being thrown. Have you checked out all of the grounds to make sure they aren't corroded?
Discussion Starter #10
As far as I know the Alternator is original. I think the low voltages are from me leaving the hood up last weekend. I do get a regular "implausible" or "intermittent" signal from the alternator now on a regular basis. I just cleared the codes and drove 50 miles and here is the new scan.
Thursday,07,May,2020,08:43:04:13256
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
Mileage: 265230km-164806mi Repair Order:
VIN: WVGPT77L07D005583 Mileage: 265230km-164806miles
Coding: 0060575
VCID: 619FA4EE0D5A96833C5-5161
Coding: 0004216
1 Fault Found:
Coding: 0022786
Coding: 0147688
Component: ELV XXXX
3 Faults Found:
1 Fault Found:
Coding: 0020030
2 Faults Found:
Component: 3002
Coding: 0110815
3 Faults Found:
000 - -
Coding: 0060575
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
Coding: 0012341
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 24
Reset counter: 255
Time Indication: 0
Coding: 0010032
Coding: 0007231
1 Fault Found:
Coding: 0000100
2 Faults Found:
Coding: 0000006
3 Faults Found:
VCID: 45D7507EB9B2DAA320D-5161
1 Fault Found:
00926 - Terminal 30
VCID: 0D47A85EA14262E328D-5185
Coding: 0015521
3 Faults Found:
Coding: 0000101
Coding: 0000085
5 Faults Found:
Coding: 0000009
Coding: 00000034
Coding: 00000034
Coding: 0014062
Coding: 0000341
Coding: 00208933
Shop #: WSC 31414
Coding: 0000002
Coding: 0000101
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 33
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Coding: 0022110
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 91
Time Indication: 0
3 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
014 - Defective
00437 - Rear Right Inner Parking Aid Sensor (G335)
014 - Defective
00436 - Rear Left Inner Parking Aid Sensor (G334)
014 - Defective
End----------(Elapsed Time: 08:09, VBatt start/end: 13.1V/13.2V)-----------
Well, you've definitely got some intermittent gremlins. Personally, I would start with checking all of the grounds. Then move on to the alternator. I'm sure there are some on here that know way more about this stuff than I do. But the alternator stuff seems to come up regularly. Could be an indication that it might have had enough. I replaced mine @ 166K Miles, but that was because the bearings were shot.
Discussion Starter #12
OK Yes, it seemed to me to be screaming ground problems. I checked the grounds on both batteries - are there other key grounds to check?
I've been reading up on alternator change. Wish I had done that when my manifold was pulled to de-carbon during my turbo replacement.....
There's a ground underneath the wiper cowl, above the ECU's that's prone to corrosion. Ground on the chassis, passenger side, sort of below the starter. Big cable going to it. Can't remember where the others are...
Discussion Starter #15
OK Much progress - but I still have a ghost.
I bit the bullet and replaced the alternator. That was one nightmare of a job. Who puts an alternator there???
What I found - 1 the alternator harness was almost definitely shorting out. So I replaced that as well. There was carbon galore in the intakes and EGR system, so I decarbed/cleaned the heck out of those. New alternator in and a set of new batteries and 90% of my codes went away. What I have remaining are fuel trim bank 1 and bank 2, "Intermittent", and exhaust pressure sensor 2 intermittent. Scan included below. Any advice on next steps? Going to try to figure out where the pressure sensor lives now I suppose.
239824
Wednesday,16,September,2020,11:17:52:13256
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVGPT77L07D005583 License Plate: DT13 SEPT
Mileage: 266070km-165328mi Repair Order:
VIN: WVGPT77L07D005583 Mileage: 266070km-165328miles
Component: V10 5,0L EDCG000AGMª8472
Coding: 0060575
VCID: 619FA4EE0D5A96833DD-5184
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
Temperature: -90.0°C
Temperature: 138.6°C
Coding: 0004216
VCID: 7F5B02969BEE40732B9-5160
Coding: 0022786
VCID: 3D27389ED1629263795-5184
1 Fault Found:
00778 - Steering Angle Sensor (G85)
Coding: 0147688
VCID: 313F14AE1D3A6603EDD-5184
Component: ELV XXXX
2 Faults Found:
00184 - Control Circuit for Engine Start/Stop Switch
VCID: 77ABEAB6B3DE7833639-5184
Component: 3002
Coding: 0110815
VCID: 47CB5A7683BEC8B3D39-5184
1 Fault Found:
000 - -
Component: V10 5,0L EDCG000AGSª8472
Coding: 0060575
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2063.12.00
Time: 00:00:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
(no units): 1.0
012373 - Exhaust Pressure Sensor 2 (G451)
P3055 - 000 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 265807 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
(no units): 48.45
Raw, Form. N/A: 000 000 124
Mass Flow: 4.27 g/s
Temperature: 354.0°C
Temperature: 21.6°C
Coding: 0012341
VCID: 2809F9CA2EE027CB3A3-5184
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 44D14D7AB288E3AB36B-5184
Coding: 0007231
VCID: 48C9594A8EA0C7CBDA3-5184
Coding: 0000100
VCID: 33331EA6E72654139F1-5184
Coding: 0000006
VCID: 70B9D1AAD6B02F0BA23-5184
2 Faults Found:
00478 - Control Module; Display & Input; Comfort CAN; Rear (J524)
00463 - Control Module for Digital Sound Package (J525)
VCID: 45D7507EB9B2DAA3215-5184
VCID: 0D47A85EA14262E3295-5184
Coding: 0015521
VCID: 3829298AFE40B74BAA3-5184
Coding: 0000101
VCID: 50F9712A76F00F0B823-5184
Coding: 0000085
VCID: 41DF446EAD9AF6831DD-4B1E
1 Fault Found:
VCID: 55F7803E4C026A23515-5184
Coding: 0000009
VCID: 78A9E98ABEC0774B6A3-5184
Coding: 00000034
Coding: 00000034
Coding: 0014062
VCID: 353720BEE9524A23B15-5160
Coding: 0000341
VCID: 3C21359ACA789B6B4EB-5184
Coding: 00208933
Shop #: WSC 31414
Coding: 0000002
Coding: 0000101
VCID: 72BDDBA2D8BC1D1B547-5184
Coding: 0022110
VCID: 392F2C8EC54AAE4355D-5184
End----------(Elapsed Time: 08:08, VBatt start/end: 13.1V/13.2V)-----------
1 - 15 of 15 Posts
