6D Trunk Elect: Bugs
6.2K views 11 replies 4 participants last post by  fullerton.benjamin
replaced battery.
brought the voltage back up to 12.4V-ish Sure starts better in our Wisconsin winters
But, no fix for the LIFTGATE MOTOR. All the same results as before.
I may replace the entire control module, but wish this could be solved with a "click"
More of the same,
When i run the "OUTPUT TEST" the module refuses all the calls.
No signal/communication = faulty wiring or dead/dying module.
Sent from my moto g(7) power using Tapatalk
Hunting for PART#
Are the suffix _/ A / C simply revisions of the same module? Are they all backwards compatible?
Any benefit from getting the newest revision?
7P6-959-107
7P6-959-107 A
7P6-959-107 C
Yes, they are revisions of the same module.
Latest is greatest. You usually cannot buy earlier revisions new; only used, as dealer OEM no longer produces them.
All should be backwards compatible.
Hard to say if any have a benefit, unless you know what changes were made. From my experience, revisions are small physical changes that do not affect function.
