1 - 1 of 1 Posts
Just picked up the Treg from getting the routine 5k maint done.
1) Oil Change: 6 qts of Synthetic
2) Remote Range fixed
3) Alignment Check (I thought it pulled to the right a little but they said, after doing an "air pressure adjustment" it came out fine...seems to be okay)
4) Rear Latch Check (mine was built after the problem was already corrected--no need for replacement)
5) Plastic panels at bottom of driver's seat loose due to small section that fell off (new piece on order should be in in a couple days)
Grand Total: $8.95
Total Time: 1 Day (dropped it off last night, picked it up after work tonight)
BEAT THAT!!
1 - 1 of 1 Posts
