2006 4.2 v8. I’m dealing with a strange set of symptoms I am trying to diagnose and curious if you all think they’re related.
I don’t have a starter or battery issue, but i am increasingly unable to start the vehicle on first try. I then have to turn the key to the left and try again with a manual crank, though I don’t need to crank long.
I’ve narrowed it down to the crankshaft position sensor or one of the fuel pumps, based on my readings here. I feel like it’s the CPS since it seems to only happen when the engine is warm. I hear the fuel pump when opening the driver door, and the vehicle doesn’t stall when driving, so I’m leaning less toward that.
If the secondary fuel pump (or filter, or regulator) is failing, is the main pump able to start the car still? Hence why I need to crank more?
Other symptoms that seem to have started at precisely the same time: the engine seems to rev higher/hold gears longer and despite so, power seems a bit down. This makes me wonder if it could be fuel pump.
Transmission seems to bang gears/shift more harshly on occasion, like a bad valve body. But could it be behaving this way because of a bad signal from the CPS? Totally realize it could be two sets of issues, though the transmission issue flared up suddenly with the hard start issue and trying to see if it could possibly be related. Holding the gears long and revving higher than usual doesn’t sound like a valve body issue to me
VCDS scan is clear.
VCDS scan is clear.
