erWin has engine specific manuals.
No need to reference "other" manuals and try to apply their values\specs to ours.
There is no data on any of the Cata or cnrb ERWIN files that refers to your degree measurement honestly this level of scrutiny is insaneerWin has engine specific manuals.
For your entire data set to be valid... you Must show cata or cnrb Erwin files explaining 00182There is no data on any of the Cata or cnrb ERWIN files that refers to your degree measurement honestly this level of scrutiny is insane
my friend I made it very clear this was not our Engines but spoke of the PREMISE
Did you not understand the context ?
Yes and it’s why your criticism perplexes me ,Not really sure why you're offended by my attempt as per my initial post to document\obtain data to potentially "validate" what many have been flagging as a tell tale sign of wear. At no point did I reference a manual spec to check against, as I haven't seen one myself. (perhaps it exists, no idea)
Did you read the initial post where I believe I mentioned that the "acceptable value" has been derived from reading numerous posts on forums about the subject and from users\techs\mechanics reporting the readings that they've taken off specimens they've had in the shop or worked on or whatever?
IDE00182,Camshaft adaptation intake bank 1: phase position,-1.30°
No excusesStill on my to do list. There aren't a lot of occasions where I have my laptop ready & the engine warm...
So yours is advanced instead of retarded?Phase value with hot engine is 3.86.
I don't see a minus in what you posted..... should I also imagine your odo reading and oci for the purpose of your contribution to this topic and so that I can add your info to the table?No, it’s minus: I think it’s impossible to have positive values.
