I ran the VAGCOM through it, and indeed misfire was one of the fault codes, but there are so many others, I'm not sure where to start with it. I bought 6 new coil packs and will also get spark plugs installed over the weekend. But I was reading about issues the brake vacuum could also have on the truck and stutterring in the shifting. When I ride the treg in sport mode, nothing happens, only when in Drive does it buck randomly.
I'm also getting a Check Oil Pressure warning on the MFI, oil is fine and just changed. Maybe the sensor? I have a new one so I will replace it.
Below is some of the more applicable code readouts from the VAGCOM.
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 42
Reset counter: 255
Mileage: 210424 km
Time Indication: 0
Freeze Frame:
RPM: 670 /min
Load: 38.4 %
Speed: 1.0 km/h
Temperature: 71.0∞C
Temperature: 20.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 212063 km
Time Indication: 0
Freeze Frame:
RPM: 2153 /min
Load: 90.9 %
Speed: 58.0 km/h
Temperature: 78.0∞C
Temperature: 17.0∞C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000774 - Cylinder 6
P0306 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 212063 km
Time Indication: 0
Freeze Frame:
RPM: 2153 /min
Load: 90.9 %
Speed: 58.0 km/h
Temperature: 78.0∞C
Temperature: 17.0∞C
Voltage: 14.097 V
