Here is some details on a previous thread that some idiot took over so I started a new one. Just an FYI I am not selling these kits or am I associated with them. I am letting you know that there is a CP4 disaster prevention kit for the 3.0 L TDI that is available now. The kit is sold by Whitbread Performance (formerly sold by Barber Automotive Solutions)
I bought the kit and installed on my CATA. My document attached has details for the CATA install not supplied by Whitbread. The attached Whitbread install instructions are for CNRA CNRB and CNPB. This kit is easy to install and is cheap insurance for your 3.0 L engine. It was only $325 CDN shipped and very easy to install. Pay attention to your engine model when you order the kit:
TDI CP4 Metering Valve Bypass Kit
Basically it takes the lift pump pressure from tank to the filter and splits it after the fuel filter to feed 1) the fuel actuator side to the two pumping elements of the CP4 to the HP fuel system and 2) feeds the cam lobe and rotating plungers of the CP4 then brings area prone to metal fartigue out through a 10 micron fuel filter to the tank. Here are two videos for details:
If you have the CP$ fail you will change the CP4, rails, lines, injectors, filters, tank wash, and more = a ton of cash. Or with the CP4 DP kit after the failure you change the CP4 and the filters.
The kit is really good. The supplied hose is 225 PSI GATES 27349 and the clamps are good quality for low pressure lines. The two screws are 12.9 socket head cap screws. The return filter is a 10 micron Earl’s Vapor Guard 731166ERL filter. There is no need to buy anything else for the install.
See attached for details. If you are interested enjoy the free info, if you are an idiot; PFO
