1 - 16 of 16 Posts
It was time to go in another direction with tires. I had been buying with not much regard to price and just wanted what was/is considered "the best" or close to it.
Both my wife's 2015 TDI Exec and my 2012 TDI Exec came with the Goodyear LS2 and while they were ok, they only lasted right around 20,000 miles, in fact, all the tires we've been using have only been able to get from 20,000 to 25,000 miles. As it is, I just put the third set of tires on my wife's 2015 and the truck only has 44,457 miles on it. Again, the LS2's worked well but the replacement price makes the tires the most expensive tires in 275 45 20.
The Pirelli Scorpion Verde A/S Plus were also good but again, barely lasted 20,000 miles.
I am running the same Pirelli Scorpion Verde A/S Plus in the same size as they started on my 2012 TDI before I sent it back to VW and kept both the tires and the wheels and they are running on my 2016 Cayenne Diesel and I'm pretty sure that sometime this summer or fall they will need to be replaced but the OEM Michelin Latitude's had, yes, once again, lasted about 20,000 miles.
Same with the Continental DSW Extreme Contact-NOT the 06's, and while they were also great, had only lasted, drum-roll-please, 20,000 or so miles and were done.
In light of all these tires that go right around $200 per tire, sometimes a little more, I decided to try the Cooper Discovery H/T Plus for $150-each and paid another $100 to have them mounted and balanced. I did have to go around and loosen all the lug bolts as they were all overtightened as the guys at the local gomeria just air impacted them on but I was able to loosen them all up with a breaker bar and then took a couple revolutions to get them all to 133 ft lbs. I had taken the truck up onto the highway and was happy when at all speeds up to 92 mph, had the truck rock steady with no vibration or anything coming through either the chassis or the steering wheel-success.
I had also made sure to set the tire pressures to the recommended 33 Front and 39 Rear and the truck is happy as the Scorpion Verde A/S Plus were totally bald on the outsides of the front tires and the rears were even below the wear bars. It was very surprising to me at how fast the tires wear once they are close to the wear bars.
If these tires get 20,000 miles, and work well in the rain, which they should as the tread pattern is like every other one out there and the treads are nice and deep, but if the tires check out, they might be my next tire.
Oh yeah, out on the highway, the tires were the same as all the others I had in the past, quiet, smooth and even though they were new, I was pushing them on the on/off ramps and around the corners after stop signs or left/right-hand turns to help "scrub them in".
I'll bet that if I ask my wife what she thinks, she will just be glad that there are new tires as she gives a full 0% of thought as to all the parameters that us hardcore forum guys are obsessed with. I'm getting to where she is but I still do care a little. More after some rain drives as I am planning on using her truck to tow the snowmobile trailer up north this upcoming weekend.
Discussion Starter #2
Wife reported a 100% better-difference this morning. How she is taking turns/curves, I. Do. Not. Know.
I do know that I had tried hard last night to get the tires to break loose on hard cornering and got some howl but otherwise, the tires are, well, tires and they hold up.
They are T-Rated to like 119 mph but about the fastest cruise is 80-85mph so I'm not in the least bit worried about that rating. All we want is 20,000 miles and for good roadholding in the rain.
You should run tires in for a couple of hundred miles - no hard cornering, no hard acceleration and no hard braking!
It's also wise to go a bit steady anyway after new tires are fitted to wear off the tire mould release solution which can cause a tire to slide unexpectedly on a wet road.
I need to order new summer tires myself for my '14 Exec next month. My Goodyear's got far more than 20K though. Probably in the high 30s. I run snows from about January to April and I have ~68k on the odometer right now. Anyhow, I was considering Yokohama Parada Spec X at $154ea. Anyone have experience with these? I'll be watching your thread too for updates as I get closer to purchasing.
Just curious, why did you choose the H/T instead of the SRX tires?
I had the H/T's on my pickup; they were good tires.
I'll also add that the trucks both tow a 7,000 boat/trailer when it is nice out and then 3,500 lbs of enclosed snowmobile trailer in the winter-adding to the tires wearing out a bit faster than those who do not tow.
I had shopped for the best tires for the money and for $150 each, the H/T looked great and happened to review very well too.
I see that the SRX are even cheaper than the H/T, maybe next time, but only if the H/T last for about 20,000-it is bad that that is all I expect but for a shorter wheelbase truck with AWD, and that is towing either a 7,000 lb boat/trailer or a 3,500 lb snowmobile trailer most every weekend in the winter, with the truck weighing 5,000 lbs-the same as a 1500 series pickup truck, it is the price I/we have to pay for the utility of it all.
If I did not have the boat to tow, I wonder if I'd have a TDI at all
Discussion Starter #8
My wife got to drive, first, in the snow/slush/mess, on the highway, and she had said that while the going was slow, the tires did well. Of course, most new all season tires would do well in driven-over snow so it is almost no surprise.
Where the tires also did really well were both a 4 mile long dirt/mud road that was the consistency of peanut butter/mashed potatoes and where the mud was 3-4" deep. My wife knew to not let her momentum down/slow, or else, so she kept on the pedal and chugged through the miles and miles of mud.
I now need to go out and clean her truck.
I'll look forward to driving the truck in the rain to see how the tires do and to see if they will last at least 20,000 miles. If they last, they will be my next set of tires for my own truck.
So I have a 2012 V6 Exec on 20” wheels and I have run the Parada’s for 3 straight sets.
Pros - Price - value - excellent
Handling - very good. The vehicle is my wife’s primary driver and when I drive, I appreciate its responsiveness and ability to hold the road.
I like you are located in New England and need an all season tire that handles winter driving, and this tire is very good for that.
Cons - mileage - last about 17-19k on 20’s with proper alignment, balancing and rotation. But this is the challenge that we have with this vehicle, especially on 20’s.
$600.00 for 4 tires makes it more digestible when you have to burn through them like I do.
Overall, I recommend them because they give you what you want without breaking the bank.
Discussion Starter #10
I'm glad I'm not the only one who has noticed the 20,000 mile, maybe 25,000 mile limit that our 5,000 lb trucks, with short wheelbases, and AWD, that tow from 3,000-7,000 lbs, who has tried all the "longest lasting" tires, read: Most Expensive tires that money can buy, and have found it to just be sort of a waste-so far.
Instead of >$900 per set, we're trying the $700 a set and if the performance is the same as we're not pushing these trucks around some orange traffic cones in parking lots on our off-days or tracking our Touaregs, and the life is even close to equal to 20,000 miles +/_ 1-2,000 miles, I can easily live with it.
My wife says the truck is riding and handling great in all the conditions/roads so far.
I'll also add that the trucks both tow a 7,000 boat/trailer when it is nice out .....
Hijacking thread......
What kind of distance\speed do you tow with this setup. I'd be curious to hear if the transmission holds final gear at 60mph and what kind of MPGs you get. When I pulled my TT at an alleged 2/3 that weight, mine didn't if left in full auto. Certainly a beat is slippery AF compared on my toaster shaped TT, but I'd love to hear what effects that weight has on the towing experience.
My 2013 came with Parada Spec-X tires that were fairly worn, but passed a safety inspection. They were okay in the rain and fairly quiet even though they were worn. Previous Treg tire experience was Pirelli Scorpions and they were very noisy when worn out.
I now run Hankook Ventus ST RH06 in the summer and am very happy with them. And the price was very good. I paid $125 US per tire compared to double for Continental DWS.
I run dedicated winter tires November through March.
Discussion Starter #13
I will tow from 120 miles from house to house or, from 25-45 miles to the boat ramps. 65-mph.
The transmission is in 8th gear when cruising at right around 2,000 rpm-no different than when there is no trailer. The truck has an awesome amount of torque, nice, quiet power, anytime I need to get the entire rig up to speed.
I get right around 13.5 mpg with the 6,000 lb boat and its 1,100 lb trailer.
The trailer has surge disc brakes on all four wheels so stopping has not been a problem nor has towing at all. The 2012 Treg TDI and my wifes 2015 TDI have been towing the boat just superbly for all these years.
Discussion Starter #15
I had a 2004 Tundra V8 4.7L 4WD and it only got from 6.5-8mpg=a pig towing the same boat.
It has to help, a lot, that the bow of the boat is shaped like an arrow as compared to a TT.
I went with the Yokohamas BTW. Probably put about 750 miles on them so far through dry and torrential rain/ponding conditions. Initially the seemed squidgy on the road but after breaking in they settled and I've had no problem whatsoever with them. Longevity not notwithstanding, I'd recommend them.
1 - 16 of 16 Posts
