1 - 2 of 2 Posts
Probably sounds like a silly thing to want to do....but....in the summer heat I need to be able to leave my golden retriever in the car with the A/C running while I make quick runs into a store (like Dollar General or to pick up a food order, etc). I don't trust leaving the car running and UNlocked. I have 2 fobs but when it's running the 2nd fob that's outside of the car with me doesn't work. It's not the fob, they both work fine for intended purposes. So does anyone have any tricks on how I can override the "can't lock from outside if engine is running" keyless entry feature?? Thanks ahead of time!!
2011 VR6 FSI LUX
I have an idea but need to ask a couple of questions first.
Does the vehicle have a start/stop button where you don't need to put the FOB in the dash spot to start the vehicle?
And if it works as mentioned above can you sit in the vehicle with it running, FOB in hand , lock the door using the lock button on the door panel not the FOB, then unlock the vehicle using the FOB unlock button?
1 - 2 of 2 Posts
