1 - 3 of 3 Posts
Can anyone tell me for sure if there is any issue with fitting 2016 18" wheels on a 2004 V8 with 18" wheels?
Also, does anyone know if the tire pressure sensors are compatible between 2016 and 2004 for the US?
I'm guessing on the first...if the offset is the same, you should be fine. Bolt pattern and center bore haven't changed, as far as I know.
Cayenne and Audi Q7 wheels also have similar bolt patterns and center bore.
With regard to TPMS -- I believe that they are different. TPMS listings for T1 and T2 have different specs than for the T3.
Yes, the wheels will fit but the TPMS parts operate on a different wavelength.
1 - 3 of 3 Posts
