1 - 11 of 11 Posts
Hi all,
Just purchased this 2015 Touareg TDI. I realize this topic has been covered several times, but wanted to get some advice. I have read all the threads on the topic I was able to find, but my issue seems to have some uniqueness to it. I am getting the image cable fault, but also some other faults. Do any of you have experience with the other faults? Also, can anyone point me to the right cables?
Does anyone know where to get the generic test cable referenced in this thread: ACC and Front Assist are not available
Cable Fault:
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H33 0035
Serial number: 005000012611147
Coding: 0AA118040000
Shop #: WSC 08567 006 1048576
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
VCID: 372B2EBDDFC60FA2FE9-8062
1 Fault Found:
0161 - Video Cable for Image Processing
C1107 02 [009] - Signal Failure
[No_camera_found_on_startup]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 23
Reset counter: 150
Mileage: 91948 km
Date: 2023.03.14
Time: 10:36:08
Outside temperature: 20.0 °C
Voltage terminal 15: 11.3 V
Control Module temperature: 23.0 °C
Other related faults:
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C213191E6E02CFA13B-8068
3 Faults Found:
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal Electronic Failure
[FAULT_UAR_NVK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 183
Mileage: 91920 km
Date: 2023.02.21
Time: 17:15:30
Control Module temperature: 15 °C
Voltage terminal 15: 12.234 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_LRRS_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 91920 km
Date: 2023.02.21
Time: 17:15:27
Voltage terminal 15: 11.368 V
93440 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VIDEO_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 150
Mileage: 91911 km
Date: 2023.02.09
Time: 09:09:45
Control Module temperature: 28 °C
Voltage terminal 15: 14.146 V
Full Scan:
Thursday,16,March,2023,12:10:52:47281
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
VIN: WVGEP9BP2FD004841 License Plate: TOUAREG
Mileage: 92376km-57399mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BP2FD004841 Mileage: 92376km-57399miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF8238D3FF820E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 25018 444 00000
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 303915A13AA8D89ABF3-8064
VINID: 9E65D58094A0096500004204046EFCF929
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 100 3374
CVN: E0C27B10
Coding: 010200000C008400000000000000000000000000
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40D945618A08481A4F3-8014
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 42724437256612 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F57DAFCC89792D3F6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC16151B6409C7AA3B-8018
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77ABEEBD9FC6CFA23E9-8022
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3214000159317010
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686200A80
VCID: 78A9ED819258C0DA373-802C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00000972742401
Coding: 26000096963C5D010020480300005D4C431C6608A2014261000000008040110000000000000000
VCID: 6A8DC7C9DC74624AB17-803E
Component: WWS 141126 033 0021
Serial number: 90243400141201213949
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20456138
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000001212140272
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01CFE86C
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231433602004
Coding: 310D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D149719E10543A6BB-8010
Coding: 3701010101
3 Faults Found:
[FAULT_UAR_NVK8_31]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 183
Mileage: 91920 km
Date: 2023.02.21
Time: 17:15:30
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 183
Mileage: 91920 km
Date: 2023.02.21
Time: 17:15:27
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 81
Reset counter: 150
Mileage: 91911 km
Date: 2023.02.09
Time: 09:09:45
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04Z H10 0043
Revision: -------- Serial number: 003NK001Y1HD Dataset Number: 7P6003V____ 1649
Coding: 00000000000000000000000000000000345A
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D34A6D9B1E5302521-8016
Seat occupied recognition:
Serial number: 5850000R14A220HEPW
Serial number: 3575LRB40532RDNK59M/
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB405D2UKGU1GOQ
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB405L2T328GHKJ
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB40592T328HA4T
Serial number: 3557BRB40612T32G8P2
Serial number: 3567BRB40632T32GRHGN
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374NL700052
Coding: 000CDD
VCID: 3D273C95FD7A25F2245-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0073271 TRW 20141124
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 983 D HW: 7P6 920 983 D
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658031214592025
Coding: 8B5733026F08CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001666022 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40651D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 41336B39105701162547
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000123129428
Coding: 00581B0000004001000001010101202020202121202020
VCID: 343119B1CE30E4BADBB-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0354185884 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDB469DF7F637E2369-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0353882520
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000130075332
Coding: 011D17205E00453005080001
VCID: 7AADF789ACD4D2CA417-802E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0354086800
Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 300141347
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO3372073%
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO34019854
Coding: 191100
Subsystem 5 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 93380068
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000130143663
Coding: 011D17205E00453005080000
VCID: 48C95D41A2B8705A873-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C14C1100420 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 363523B9D8CCF6AAE5F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0016
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156L/0E8124542
Coding: 020007020100000001
VCID: 2411E9F17ED0743A4BB-8070
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273K$0EB004434
Coding: 010200050040E9EF79022B0E00000003F00001030000000000
VCID: 3C213191E6602CFA13B-8068
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H53 0046
Serial number: VWZ8Z9PX8002BG
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000129294137
Coding: 011817200000253005080000
Part No SW: 7P6 907 273 H HW: 5Q0 907 273
Component: RDKBERU30 H04 0002
Serial number: 40000000006835 Dataset Number: 7P6096V____ 0026
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 41DF40658102411240D-8014
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0353907696 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H08000 Serial number: 525 PA8J4Y1885
Coding: 0130001
VCID: 372B2EBDD3460FA2FE9-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 327400011 Dataset Number: 7p0771v____ 0012
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000129295468
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F2885E9D219D208D-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007063634_3069
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2D3789ECD412CA017-806E
ROD: EV_BTR_002.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 150
Mileage: 91948 km
Date: 2023.03.14
Time: 10:36:08
End----------(Elapsed Time: 02:29, VBatt start/end: 14.4V/14.5V)-----------
I cleared them and they come back immediately.
Friday,17,March,2023,14:04:05:47281
www.Ross-Tech.com
VIN: WVGEP9BP2FD004841 Mileage: 92492km-57471miles
Readiness: 0 0 0 1 1
CVN: E0C27B10
Revision: 00002001
Coding: B686200A80
Coding: 004DBD
Coding: 025223
Coding: 310D04
Coding: 3701010101
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 152
Mileage: 92492 km
Date: 2023.03.17
Time: 13:58:52
Control Module temperature: 24 °C
Voltage terminal 15: 13.395 V
Coding: 000CDD
Coding: 000103AD00
Coding: 030221
Coding: 030221
Coding: 191100
Coding: 191100
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Coding: B00000
Coding: B00000
Coding: 0130001
Coding: 0533314003
Coding: 69020000
Slave 1:
Coding: 3701010101
ROD: EV_BTR_002.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 92492 km
Date: 2023.03.17
Time: 13:59:01
Outside temperature: 16.0 °C
Voltage terminal 15: 13.6 V
Control Module temperature: 26.0 °C
End----------(Elapsed Time: 02:23, VBatt start/end: 13.9V/14.6V)-----------
Discussion Starter · #6 ·
Post full scan results.
Then read up
Thank you for the link SaVageSoot. I read through it and the SSP. I definitely understand that several systems interact with each other and one issue can cause a number of items to fall into a fault state or restricted use state. The only cable I have been able to find is a Kufatec unit ( KUFATEC ). I have reached out to them, but not heard back yet on if this is the correct cable for a 2015 7P as I have. They state in the cable description that this cable is for Address 85, but if you have Address 8E you need a different part number. I show to have both addresses, but the fault is showing on 8E. The suggested part number on Kufatec sight for an 8E is not a cable at all.
Description from Kufatec:
Product information "Cable set Traffic sign recognition for VW Touareg 7P"
  • Cable set to retrofit the camera-based traffic sign recognition
  • The supported speed limits are displayed in the multi-function display
  • Suitable for VW Touareg 7P from model year 2013
Scope of delivery:
  • Cable set
Note:
  • After the installation you need to code the vehicle
  • Only suitable for vehicles with diagnostic address 85 (camera in the windscreen)
  • Vehicles without diagnostic address 85 on request
  • Vehicles with diagnostic address 8E please use item number 40560
  • The CAN Gateway must be a Highline version
  • For retrofitting there some other items required (Control unit, holder etc.)
Part Number 40560 link : KUFATEC
2015 Touareg TDI Lux
I had the exact same trouble codes on our 2015 TDI. I replaced the cable with the one from Kufatec and it did not solve the problem. I gave up and took to dealer, it ended up being the actual front camera was bad.
1 - 11 of 11 Posts
