Oil dipstick can be found here
Oil Level Dipstick (V6 3.0L TDI) - 059115611T - IDParts.com
I did too but 3 weeks ago my oil sensor took a dump and showed that I was 1qt low then an overfill. The good thing is I bought a dipstick to verify my oil level (which was/is right on), the bad thing is the oil sensor is on back orderWell that sucks! Maybe drill a hole in the engine cover. Oh well, I have learned to live with out a dip stick on my 2011 135i.
Unless VW changed the engine cover on the 2013 TDI, there is no need to pull anything on the 2012. It is exposed for easy checking once the stick is installed.I just pulled of my engine cover off and found the ds tube and plug. I think I will order a ds.
I assume you mean that you ordered it from the local dealer?I decided to order a dipstick for my 2012 last week while in for my 1 year service. It cost $ 20 and change and arrived in a day.
Yes...it was not in stock, but arrived in one day.I assume you mean that you ordered it from the local dealer?
Do you have a part number? I want to make sure I get the correct one... ThanksYes...it was not in stock, but arrived in one day.
there is no way
its not visible on 2013u sure you stuck it into the dipstick tube? it's pretty visible without the cover off on the '11. ;-)
059115611aa is what I ordered.Do you have a part number? I want to make sure I get the correct one... Thanks
