You need to stick with ONE thread and input ALL information into that single thread. This is too confusing.
www.clubtouareg.com
P1592
Touareg2013 v6 TDI 3.0 Hi I have P1592 implausible correlation I change the map oem bosch same code in VCDS actual value is higher of 200-/+hpa Pin 1 ground to bat- less 0.5 ohm pin 2-3 key on engine off 4.9v What I Miss ?help
