1 - 20 of 42 Posts
I have the upgraded head-unit in my Touareg lux with the nav and I started to have an issues where only the passenger door speaker will play music on it. I noticed the radio is cutting in and out, the Bluetooth and iPod all are doing the same thing where only one speaker will work. I’ve rebooted the headunit by holding down multiple buttons and the problem was still there. Looking for help.
Anyone have a solution to this problem? I can’t get the head unit to play in stereo at all even after a factory reset of all settings and rebooting it several times.
This may sound stupid but did you check the balance + fader controls to make sure it's not set to one speaker?
Yep everything is in the middle, Ive tried tweaking it and could only get the passenger front speaker to work.
So made a phone with the Touareg and all the speakers work in that mode.... what gives
I tried finding out online if the RNS850's use a separate audio amplifier or if it's built in. So far nothing.
The reason is that earlier year Tregs had an amplifier mounted in the back of the vehicle. Some who had audio issues had success in getting it back by either disconnecting the plugs to the amp and then reconnecting them, or pulling the fuse for the amp and reinstalling it to reset the amp.
The only odd thing is that you said your telephone sounds through all 4 speakers.
Maybe someone with more knowledge of the basic RNS850 audio system will be able to chime in and help.
Learner
Let me know what you seek re the setup.
For dynaudio the amp is separate, housed in the rear left section of the boot
Learner
You need to set it up using vcds, certain it will be the central control module and then maybe the nav as well
Discussion Starter #13
I’m gonna try disconnecting the battery this week and see if that helps
The RNS850 consists of the display in the dash, the main processing unit in the glovebox, the radio amplifier behind the right trunk trim panel, and the amplifier behind the right trunk trim panel. If you have a CD changer or TV unit theres additional modules behind the right trunk trim panel as well. They are all networked and communicate together over a fibre-optic (MOST) system.
Discussion Starter #15
Thanks for the info! Very interesting
So if all the RNS850's have an amplifier for sound mounted behind the right trunk trim panel and the OP might have a problem with it, or the radio amp... wouldn't there be a fuse for them in the fuse box that he could pull and reinstall to reset the amp(s) rather than disconnecting his battery?
Discussion Starter #17
Hopefully this is the correct box I needed to take out located on the passenger side truck
That’s the radio tuner. I was wrong before, the amp is behind the left trim panel. Must’ve been thinking of the precious gen.
Discussion Starter #19
I had the driver side panel removed and didn’t see it unless it’s towards the back of the seat.
Discussion Starter #20
Removed battery turned on the headunits with the battery disconnected and other lights and waited 5 mins plugged it back in.... same issue
1 - 20 of 42 Posts
