1 - 3 of 3 Posts
Hi, brand new guy here and I am doing working on my touareg cooling system for the first time. My water pump began leaking profusely from the shaft, and would drain the resivor tank after one night sitting. Thankfully I did not ever overheat the engine. Pump replacement has been smooth with no issues yet, but for the life of me I cannot find a coolant filler neck.
From what I understand I need to use a power air bleeder to puge the system, but I cannot figure out where to put it.
Any help would be greatly appreciated.
2011 VR6 FSI LUX
If you plan on sticking around here visit your profile page and fill out your Treg particulars. It'll help others help you down the road.
With that said I had watched the video below a few months back. In the video they use one of the coolant refill tools. It's not on a Touareg but I believe the principle is the same. I believe it uses air to create vacuum in the system to draw in the coolant and the air out.
At the 17:48 mark is where they go over it.
1 - 3 of 3 Posts
