1 - 8 of 32 Posts
douggoldberg
Discussion starter · #1 ·
Folks, I thought I would share my odyssey to enhance the sound of the Dynaudio system in my Exec. First a few disclaimers; I'm OCD, an audiophile, and an electrical engineer. Not a good combo to be happy with any factory system. I thought the stock Dynaudio was actualy pretty good but lacking in any "real" bottom end. So starts my journey...
I decided to use the left rear cutout for a sub. I'd seen this done on few installs and it looked like a great location (it is). I then modeled a number of drivers that I had worked with before and selected a wonderful, long excursion, 8" Tang Bang (from Parts Express) that can be had for ~$80.00 on sale. I sized the interior volume of the enclosure to provide a Q .7. I then set off to build the fiberglass enclosure. Not fun. Covered with vinyl and painted to match the interior it looks quite good though. I then measured the completed system and it matched the predicted data very well. With cabin gain its flat to about 25 Hz. My loving wife bought me an Alpine 500W sub amp that is provisioned with 4th order high pass / low pass and speaker level inputs as I desired.
The Dynaudio 12 channel amp is located behind the left wheel well cover which works out nicely as this is where the sub is mounted. I tapped into the front woofer amplifier outputs to feed the sub amp. The not-fun part was ripping the rear cabin apart to access all wiring and install the sub and amplifier. Not for the faint of heart. Have plenty of spare trim clips and buy a good set of trim removal tools if you are going to attempt this.
Once installed I adjusted the crossover to 60 Hz (its a true subwoofer only) and set the gain and EQ to a get a good house curve (+ 4dB at 30 Hz) at the drivers seat. You could do this by ear but good a measurement system is recommended.
OK this mod totally transforms the system! Wow its a fantastic upgrade and well worth the time and money. It really fills out the low end and provides a much more dynamic system. Very, very happy with the results. Looks great too.
Discussion starter · #3 ·
I spent $80 for the sub driver itself, my wife paid $220 for the sub amp and then I spent probably another $150 in misc materials. About $450.00 in parts. A local high-end car stereo shop, which does very nice work, quoted $1400.00 including making the custom enclosure. I thought "surely I can do this better for less". Of course if I added up all my obsessive compulsive labor.. But it the end it was fun and I have the satisfaction of knowing its well engineered and installed properly. All the connections are soldered, heat shrunk and strain releaved. Its designed to last the life of the car. Had I not done it myself I would of had to stand over the installer and insist he did it properly. Your OCD may vary....
Discussion starter · #7 ·
Hey dont call my grill ugly! Actually I played with a few grills and liked that one the best as its quite sturdy. It is painted to match the interior. Im often carrying quite a bit of stuff in the back and was concerned about woofer / grill damage so I choose a very robust grill.
Forgot to mention earlier that while I was tinkering with the subwoofer install I also modified the fuse box so that my power outlets are always powered. I usually keep my phone in the center console bin and I wanted to be able to maintain charging when the ignition is off.
1 - 8 of 32 Posts
