1 - 7 of 7 Posts
Bluesky
Discussion starter · #1 ·
Whats the "MUST REPLACE" items that I should replace before it breaks and leaves us stranded on a vacation somewhere? I.E water pump, injectors, timing chain etc. Runs great, getting ready to do full fluid exchange and trans service, new rotors brakes, lower control arm bushing have worn out. Is it worth $5-$8k in maintenance and upkeep to give us peace of mind that what could brake has been replaced?
Water pump, engine coolant, both thermostats, serpentine belt w/ all idlers and tensioners, any coolant hoses that are cracked, overly soft, or weeping fluid. You can check the timing chain and DPF ash loading in VCDS per Soot's threads.
Why was the HPFP replaced?
I would make sure every step of the maintenance schedule has been completed for one
Agreed with the above post.
Don't listen to VW with their "Lifetime Fluid" B.S. either.
Reactions: Bluesky
1 - 7 of 7 Posts
