1 - 6 of 6 Posts
Hey guys,
So awhile ago I noticed I was missing this on the passenger side of my radiator Here I was lucky enough to actually find it jammed into a corner today beside my air intake. Now I notice that it requires a bolt through the back of it to keep it attached to the front grill area. My drivers side one is missing too or else I would just use that to compare. Anyone know what size / length bolt this is? I see it has treading on the inside of this mounting bracket so last thing I want to do is **** up the treads with the wrong size bolt / screw.
I am also curious if I really need the clip that goes though the mounting bracket and the radiator mounting bushing or if I could just fasten something with a bolt?
It's not a standard fastener... just go grab it at the dealer.... it will only cost a dollar or three WHT003956
Hey I am not looking for the bracket I am looking for the bolt that is used to attached this bracket to the front grill / rack area. I would love to go to the dealer even if I had to pay 10$ for this .50$ bolt but they are 500miles away.
You asked about the fastener.
I told you it's not standard (read, you can't go to hardware store and get a 1/4-20*1 off the shelf) and gave you a part number to either order it online or to look it up so that you understand the problem.....
You responded with I'm not looking for the bracket... Totally irrelevant, so I asked to to actually look at and read what I posted.....
Now you're barking about not being helpful?
Did you expect me to come out to your stix to deliver it for you? Or to build a local shop that specializes in VAG screws close to you? How am I not being helpful?
Pull up your skirt, retap the block for a standard pitch fastener, use an insert, figure something out. I don't know what miracle answer you're expecting here.
1 - 6 of 6 Posts
