1 - 10 of 10 Posts
Anyone using an adhesive heater on the oil pan? It’s a thin pad with adhesive backing that will afix to oil pan. Also is there room for an electric battery wrap? Just wanting to make it easier to fire up in the morning, wife has a shorter commute to work (16 Kms) and if I could bring it to op temp sooner would only be better. She has a tendency to roll out on the starter and mash the fuel peddle, so I can only see warmer oil/block to be an advantage. No garage, inside shop to store it.... and the oil pan heater seems like a reasonable solution for warming up the block and oil.
Suggestion appreciated,
j
Please put your location and model [even though it's in your signature!] in the little box under your user name so others can help you better.
Go to USER CP near the top of the page and select EDIT YOUR DETAILS.
I’d suggest the Canadian Polar Pad....good product & can be found on Amazon.ca.
I might end up putting one on our Touareg as it can get colder than -40c here but ours is garage kept & won’t ever be sitting out in the cold longer than a few hours ever.
As far as a battery blanket, I don’t think you will need one as the battery is somewhat sealed under the drivers seat.
I have a pad heater on mine. It does nearly nothing. I installed a circulating heater (1000W Philips and Temro from Frostheater.com) and it is much better. Cost was only a bit more than the pad heater. I run mine on a timer to come on 2-3 hours before I leave in the morning depending on the ambient temperatures. Install was simple. She starts at -35°C easily.
As long as your battery is reasonably new, it should be good. I do not believe there is room for a battery blanket. Plus it would be a fire hazard under the driver's seat.
Nothing like a nice car-b-q
Did you install the frost heater on your 2013 Touareg?
There is no Frostheater available for the 2013+ TDI.
1 - 10 of 10 Posts
