2011 VW Touareg overheating
4.1K views 10 replies 6 participants last post by  mactac
Ok so.. I have a 2011 VW Touareg TDI Luxe (diese)
So when you drive the car with the a/c on, about 4/-5 miles down the road (@70mph) it pegs out hot. When I turn the air off it runs perfect.. any thoughts? Talked to a few places that said to replace the ECM ..just need a few More opinions, ideas, thoughts, whatever..any help will be mucho appreciated!!
#4 · (Edited)
VCDS is the first thing as it avoids the guesswork. It could be a sensor it could be the ECM. This YT is interesting. Turned out , after replacing sensors & tearing their hair out to be dry joints on the ECM pcb. I would most likely start with a new thermostat & take it from there unless VCDS was forthcoming.
Any DIY on a Touareg needs access to VCDS unless you want to just throw parts at it & hope.
Is the VW Touareg a LEMON? (Crazy Overheating Issue!) - YouTube
Typically when this happens, the AC fan isn't kicking on to help disperse the additional heat. Confirm by looking underhood and see if fan kicks on with AC turning on. Though, as Jeff said, 280* is HOT and would cause imminent damage. It could potentially be a funky reading.
Come back with vagcom scan.
Radiator, large coolant hoses, tstat housing...any # of places that carry coolant. If it's running that hot you'll see red flags somewhere.
