Thanks for the update. It is common on here to offer a solution & never here anything from the OP again. Check the fuses again!! I have LED reverse bulbs which are bright & dont give error codes or blow fuses.and now the freaking horn wont work..... ughhhhh
right hand side of car fuse box, fuse # 2 on top. i had it in slot 3 instead of slot 2.Thanks for the update. It is common on here to offer a solution & never here anything from the OP again. Check the fuses again!! I have LED reverse bulbs which are bright & dont give error codes or blow fuses.Out of interest which fuse was it?
he got frustrated and pulled every single fuse and inspected every socketDo you know what made him realise it was in the wrong slot?
yes, except now my horn doesnt work and the fuse thats apparently for the horn is fine......Wow that sucks. Glad it was simple anyhow
100& working before this. (i often have my hand on it) going to check behind read trunk panel fuses tonight. its only fuse i havent checked yet.Touareg horns aren't the most reliable.
Are you sure it was working before thus episode?
